Greetings @mmccullotn,
Well if you are trying to avoid recovering and re-installing the system then there’s one method I can think of that might work.
First interrupt the boot process so you have access to the U-Boot prompt. Then in that prompt run ums 0 mmc 0
. What this command does is turns the internal eMMC into a mountable USB-like device. Via USB OTG you can then edit the overlays.txt
file from your development PC, and remove your bad overlay to allow the system to boot again.
