Hi @avionics,
Yes, you’re correct. Even though the pwm2 is disabled there, the pin function will have to change somewhere in the device tree as well to activate the GPIO function. Were you able to modify the device tree to activate de GPIO function? It should be possible to do it with an overlay too if you prefer.
There are two lines related to the same pin because some pins of the module are connected to two different pins of the processor (imx6, in this case). So, with that, we can achieve more functions in the same pin. This is better explained in the Colibri iMX6 Datasheet, page 19:
Some of the i.MX6 pins are paired and share the same SODIMM pin. When using one of these
pins, make sure that the unused pin the pair is tri-stated or configurator as input to avoid
undesired behaviour and/or hardware damage. The following table list all SODIMM pins that have
more than one i.MX6 pin connected:
Pin 67, once the GPIO is activated, it uses GPIO1_IO01. Therefore, the configuration should be
interrupt-parent = <&gpio1>;
interrupts = <1 0x2>;
The default is &gpio3
and <27 0x2>
, which points to GPIO3_IO27 (pin 73). So by changing it to the above, we’re changing from GPIO3_IO27 (pin 73) to GPIO1_IO01 (pin 67).
Yes, you are correct, the default is pin 73.
Also correct, can you please try that?
Checking the Documentation about this driver, there isn’t a good explanation about it:
* Microchip MCP251X stand-alone CAN controller device tree bindings
Required properties:
- compatible: Should be one of the following:
- "microchip,mcp2510" for MCP2510.
- "microchip,mcp2515" for MCP2515.
- "microchip,mcp25625" for MCP25625.
- reg: SPI chip select.
- clocks: The clock feeding the CAN controller.
- interrupts: Should contain IRQ line for the CAN controller.
Optional properties:
- vdd-supply: Regulator that powers the CAN controller.
- xceiver-supply: Regulator that powers the CAN transceiver.
Example:
can0: can@1 {
compatible = "microchip,mcp2515";
reg = <1>;
clocks = <&clk24m>;
interrupt-parent = <&gpio4>;
interrupts = <13 0x2>;
vdd-supply = <®5v0>;
xceiver-supply = <®5v0>;
However the source code of the IRQ explains it a little better:
* IRQ line status.
* Bits 0-7 are the same as the IRQF_* bits in linux/interrupt.h
* IRQ_TYPE_NONE - default, unspecified type
* IRQ_TYPE_EDGE_RISING - rising edge triggered
* IRQ_TYPE_EDGE_FALLING - falling edge triggered
* IRQ_TYPE_EDGE_BOTH - rising and falling edge triggered
* IRQ_TYPE_LEVEL_HIGH - high level triggered
* IRQ_TYPE_LEVEL_LOW - low level triggered
* IRQ_TYPE_LEVEL_MASK - Mask to filter out the level bits
* IRQ_TYPE_SENSE_MASK - Mask for all the above bits
* IRQ_TYPE_DEFAULT - For use by some PICs to ask irq_set_type
* to setup the HW to a sane default (used
* by irqdomain map() callbacks to synchronize
* the HW state and SW flags for a newly
* allocated descriptor).
* IRQ_TYPE_PROBE - Special flag for probing in progress
* Bits which can be modified via irq_set/clear/modify_status_flags()
* IRQ_LEVEL - Interrupt is level type. Will be also
* updated in the code when the above trigger
* bits are modified via irq_set_irq_type()
* IRQ_PER_CPU - Mark an interrupt PER_CPU. Will protect
* it from affinity setting
* IRQ_NOPROBE - Interrupt cannot be probed by autoprobing
* IRQ_NOREQUEST - Interrupt cannot be requested via
* request_irq()
* IRQ_NOTHREAD - Interrupt cannot be threaded
* IRQ_NOAUTOEN - Interrupt is not automatically enabled in
* request/setup_irq()
* IRQ_NO_BALANCING - Interrupt cannot be balanced (affinity set)
* IRQ_MOVE_PCNTXT - Interrupt can be migrated from process context
* IRQ_NESTED_THREAD - Interrupt nests into another thread
* IRQ_PER_CPU_DEVID - Dev_id is a per-cpu variable
* IRQ_IS_POLLED - Always polled by another interrupt. Exclude
* it from the spurious interrupt detection
* mechanism and from core side polling.
* IRQ_DISABLE_UNLAZY - Disable lazy irq disable
enum {
IRQ_TYPE_NONE = 0x00000000,
IRQ_TYPE_EDGE_RISING = 0x00000001,
IRQ_TYPE_EDGE_FALLING = 0x00000002,
IRQ_TYPE_EDGE_BOTH = (IRQ_TYPE_EDGE_FALLING | IRQ_TYPE_EDGE_RISING),
IRQ_TYPE_LEVEL_HIGH = 0x00000004,
IRQ_TYPE_LEVEL_LOW = 0x00000008,
IRQ_TYPE_LEVEL_MASK = (IRQ_TYPE_LEVEL_LOW | IRQ_TYPE_LEVEL_HIGH),
IRQ_TYPE_SENSE_MASK = 0x0000000f,
IRQ_TYPE_DEFAULT = IRQ_TYPE_SENSE_MASK,
IRQ_TYPE_PROBE = 0x00000010,
IRQ_LEVEL = (1 << 8),
IRQ_PER_CPU = (1 << 9),
IRQ_NOPROBE = (1 << 10),
IRQ_NOREQUEST = (1 << 11),
IRQ_NOAUTOEN = (1 << 12),
IRQ_NO_BALANCING = (1 << 13),
IRQ_MOVE_PCNTXT = (1 << 14),
IRQ_NESTED_THREAD = (1 << 15),
IRQ_NOTHREAD = (1 << 16),
IRQ_PER_CPU_DEVID = (1 << 17),
IRQ_IS_POLLED = (1 << 18),
IRQ_DISABLE_UNLAZY = (1 << 19),
Please let me know if you have any questions.
Hiago.
