It seems you’re encountering a permissions issue when trying to compile your C++ project for the iMX6ULL using Docker. This is likely due to how the volume is mounted and the user permissions within the container. Here are some steps to help you resolve this:
Check Volume Mount Permissions:
- Ensure the directory
/home/XXXXXX/test0on your host has the correct permissions for thetorizonuser inside the container. You can temporarily set more permissive permissions to test this:chmod -R 777 /home/XXXXXX/test0 - If this resolves the issue, adjust the permissions to be more secure, ensuring the
torizonuser has the necessary access.
Verify User and Group IDs:
- Make sure the user and group IDs match between your host and the container. The
torizonuser inside the container should have the same UID and GID as your host user. - You can specify these IDs in your Docker run command using the
--userflag:docker run --rm -it -v /home/XXXXXX/test0:/home/torizon/app --user $(id -u):$(id -g) cross-toolchain-arm-test0-container bash
Check Docker Group Membership:
- Ensure your host user is part of the
dockergroup to avoid permission issues when running Docker commands withoutsudo:sudo usermod -aG docker $USER - Log out and back in for the changes to take effect.
By following these steps, you should be able to resolve the permission issues and successfully compile your project for the iMX6ULL target. If the problem persists, double-check your Docker and user configurations.
Toradex AI Assistant
