Hi!
I am doing a build of torizoncore following this Build TorizonCore from Source With Yocto Project
and run Repo init
repo init -u https://git.toradex.com/toradex-manifest.git -b refs/tags/5.7.0 -m torizoncore/default.xml
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "aarch64-tdx-linux"
MACHINE = "verdin-imx8mm"
DISTRO = "torizon-upstream"
DISTRO_VERSION = "5.7.0-devel-20230217000644+build.0"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta-toradex-torizon = "HEAD:35ee5073578e3a62891e5cfdc64aaf310e7c1f4c"
meta-toradex-distro = "HEAD:cbde0286cb85bc445e70210b8df38f29b4784c08"
meta-toradex-bsp-common = "HEAD:029a663150449a5e71b84dd4000476754d525c8c"
meta-oe
meta-networking
meta-filesystems
meta-python
meta-perl = "HEAD:8ff12bfffcf0840d5518788a53d88d708ad3aae0"
meta-virtualization = "HEAD:f6b88c1d2f515ffac90457c0d649d6c805fff736"
meta-updater = "HEAD:eba4b74e6e30fb70d26b3034d18ece4d331fca04"
meta-toradex-nxp = "HEAD:ee63c90fde9fde0229bff9ac1c5cffe356fc4f41"
meta-freescale = "HEAD:3cb29cff92568ea835ef070490f185349d712837"
meta-freescale-3rdparty = "HEAD:c52f64973cd4043a5e8be1c7e29bb9690eb4c3e5"
meta-yocto-bsp
meta-poky = "HEAD:7e0063a8546250c4c5b9454cfa89fff451a280ee"
meta-security = "HEAD:c62970fda82acf75035243766ecd195243e0f82a"
meta = "HEAD:add860e1a69f848097bbc511137a62d5746e5019"
The error that shows me is the following
Initialising tasks: 100% |#######################################################################################################################################| Time: 0:00:06
Sstate summary: Wanted 357 Found 295 Missed 62 Current 1783 (82% match, 97% complete)
NOTE: Executing Tasks
ERROR: linux-toradex-5.4.193+gitAUTOINC+cf62fa8fd9_f782992971-r0 do_kernel_localversion: Execution of 'Torizoncore_Driver/Build1/tmp/work/verdin_imx8mm-tdx-linux/linux-toradex/5.4.193+gitAUTOINC+cf62fa8fd9_f782992971-r0/temp/run.do_kernel_localversion.4020041' failed with exit code 2
ERROR: Logfile of failure stored in: Torizoncore_Driver/Build1/tmp/work/verdin_imx8mm-tdx-linux/linux-toradex/5.4.193+gitAUTOINC+cf62fa8fd9_f782992971-r0/temp/log.do_kernel_localversion.4020041
Log data follows:
| DEBUG: Executing shell function do_kernel_localversion
| Torizoncore_Driver/Build1/tmp/work/verdin_imx8mm-tdx-linux/linux-toradex/5.4.193+gitAUTOINC+cf62fa8fd9_f782992971-r0/temp/run.do_kernel_localversion.4020041: 121: cannot open MECH/Torizoncore_Driver/Build1/tmp/work/verdin_imx8mm-tdx-linux/linux-toradex/5.4.193+gitAUTOINC+cf62fa8fd9_f782992971-r0/defconfig: No such file
| WARNING: exit code 2 from a shell command.
| ERROR: Execution of 'Torizoncore_Driver/Build1/tmp/work/verdin_imx8mm-tdx-linux/linux-toradex/5.4.193+gitAUTOINC+cf62fa8fd9_f782992971-r0/temp/run.do_kernel_localversion.4020041' failed with exit code 2
ERROR: Task (Torizoncore_Driver/Build1/conf/../../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb:do_kernel_localversion) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6346 tasks of which 6345 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 3 seconds
Summary: 1 task failed:
/Torizoncore_Driver/Build1/conf/../../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb:do_kernel_localversion
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
I hope you can help me
Ivan
