This is a document describing how to Remote Access the TorizonCore GUI Using VNC or RDP.
I have some doubts on what to do with docker-compoe.yml
The instructions say that I must add ENABLE_VNC=1 or ENABLE_RDP=1 but the video adds -ENABLE_VNC=1 (with the starting - character).
Looking to the command line for i.MX8M-Mini, it seems that this is expanded to --env ENABLE_VNC=1
But the “standard” docker-compose.yml for i.MX8M-Mini has
environment:
ACCEPT_FSL_EULA: '1'
and it seems that this is expanded into -e ACCEPT_FSL_EULA=1
It’s not clear to me how to fill environment: section of docker-compose.yml so that it’s expanded in the expected way.
Is the following snippet correct for i.MX8M-Mini?
From what I can see here is that there might be a typo in the video. I will forward that if that’s really the case. As from the docker documentation I can see this.
It seems like there has to be a space between “-” and “ENABLE_VNC=1”. I would expect that this has some effect on it.
environment:
- ENABLE_VNC=1
- ACCEPT_FSL_EULA=1
Can you try this and see if that changed anything?
