Based on the Verdin Development Board V1.1 Datasheet, I can provide the following clarifications regarding the power supply configuration at X58 and X57:
Maximum Input Current and Power Limits
The Barrel Jack Power Connector (X58) and Terminal Block Power Connector (X57) are electrically connected together(1). The maximum input current is limited to 5A(1).
For applications dissipating more than 35W, you should work with a higher input voltage, up to 24V(1).
Input Protection Circuit Limitations
The power supply input is protected against reverse voltage polarity, overvoltage, undervoltage, and short circuits, with the protection circuit limiting the maximum input current to approximately 5A(1).
On-Board Power Supply Capabilities
The on-board power supplies provide the following nominal voltages and maximum currents(1):
- 5V: 8A (40W max)
- 3.3V: 8A (26.4W max)
- 1.8V: 2A (3.6W max)
Available Power at X57 for External Use
Since X57 and X58 are electrically tied together and share the same 5A current limit(1), the current available at X57 for your mezzanine board depends on how much current the Verdin iMX95 SoM and other Development Board peripherals are consuming.
Important consideration: The 5A limit applies to the total input current through both connectors combined. You’ll need to subtract the power consumption of:
- The Verdin iMX95 SoM
- Active peripherals on the Development Board (Ethernet, USB, displays, etc.)
- On-board regulators’ efficiency losses
Using X57 for a Buck Converter
Yes, you can use the supply available at X57 as input to a dedicated 12V buck converter on your mezzanine board. However, you must ensure that the combined current draw from the SoM, Development Board peripherals, and your mezzanine board stays within the 5A maximum input current limit(1).
Design Recommendations
To establish your available power budget:
- Measure or estimate the current consumption of your Verdin iMX95 configuration under typical operating conditions
- Account for all active peripherals on the Development Board
- Subtract this from the 5A limit to determine available current for your mezzanine board
- Design with margin for transient loads and efficiency losses
For applications requiring more than the available power budget, consider using a separate, dedicated power supply for your mezzanine board rather than drawing from X57.
