After changing appargs in Torizon CONFIGURATIONS, the image is rebuilt and deployed again (in debug mode), so that it takes a very long time. Is there another way to change the application arguments without build/deploy operation ?
I’ve talked with our VSCode extension team, and unfortunately there isn’t much we can do to avoid building and deploying the container when changing the configurations, because that’s the way the extension back-end (moses) works: it generates a Dockerfile from the configuration options and from there it builds and deploys the new container.
You can try to avoid redeploying the container without using VSCode and our IDE extension, through the use of environment variables as app arguments in the Dockerfile and setting them when running the container. The downside is you won’t have the debug interface easily accessible nor any other features our extension has.
Currently how long exactly does it take to deploy your project? Maybe consider changing the approach altogether if it’s possible, like hard coding the arguments for a period if they’re for test purposes.
Note that I use right quote (ascii 60) in order to obtain the result string of cat appargs.txt which therfore expands to myinptufile.ini --myflag1 --myflag2
