I try to get UART-Output on UART2.
I Followed This , but i’m only able to get the U-Boot on UART 2. I have not changed pinmuxing, could that be an error?
Output UART2:
SDP: initialize...
SDP: handle requests...
Downloading file of size 370176 to 0x177fffc0... done
Jumping to header at 0x177fffc0
Header Tag is not a IMX image
Then it starts on UART1:
Apalis iMX6 # bmode usb
resetting ...
U-Boot 2016.11-00015-gf4db39e-dirty (Aug 24 2018 - 08:23:28 +0200)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: WDOG
I2C: ready
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
auto-detected panel HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05203276
Net: using PHY at 7
FEC [PRIME]
Booting from internal eMMC chip...
reading imx6q-apalis-eval.dtb
54181 bytes read in 18 ms (2.9 MiB/s)
reading zImage
5366048 bytes read in 200 ms (25.6 MiB/s)
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Using Device Tree in place at 12000000, end 120103a4
Starting kernel ...
[ 0.000000] Linux version 4.9.87-2.8.3+g07d40f6f (oe-user@oe-host) (gcc vers8
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[ 0.000000] OF: fdt:Machine model: Toradex Apalis iMX6Q/D Module on Apalis Ed
[ 0.000000] Reserved memory: created CMA memory pool at 0x7c000000, size 320B
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id sharl
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @e5797000 s25612 r8192 d23540 u5734
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa8
[ 0.000000] Kernel command line: vmalloc=400M user_debug=30 ip=off root=/devM
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Memory: 1739068K/2097152K available (8192K kernel code, 279K rwd)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe7000000 - 0xff800000 ( 392 MB)
[ 0.000000] lowmem : 0x80000000 - 0xe6800000 (1640 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x80900000 (9184 kB)
[ 0.000000] .init : 0x80b00000 - 0x80c00000 (1024 kB)
[ 0.000000] .data : 0x80c00000 - 0x80c45ee0 ( 280 kB)
[ 0.000000] .bss : 0x80c45ee0 - 0x80cb3e0c ( 440 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L2C-310 errata 752271 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000007] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 7s
[ 0.000025] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffffs
[ 0.001552] Console: colour dummy device 80x30
[ 0.002155] console [tty1] enabled
[ 0.002187] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.002231] pid_max: default: 32768 minimum: 301
[ 0.002342] Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.002370] Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.003018] CPU: Testing write buffer coherency: ok
[ 0.003383] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003462] Setting up static identity map for 0x10100000 - 0x10100058
[ 0.005329] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006104] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006859] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006960] Brought up 4 CPUs
[ 0.007045] SMP: Total of 4 processors activated (24.00 BogoMIPS).
[ 0.007067] CPU: All CPU(s) started in SVC mode.
[ 0.007888] devtmpfs: initialized
[ 0.021507] VFP support v0.3: implementor 41 architecture 3 part 30 variant 4
[ 0.021848] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.021899] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.039143] pinctrl core: initialized pinctrl subsystem
[ 0.040356] NET: Registered protocol family 16
[ 0.047206] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069581] cpuidle: using governor menu
[ 0.069882] CPU identified as i.MX6Q, silicon rev 1.5
[ 0.094947] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint.
[ 0.094999] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.096032] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.097761] imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
[ 0.097900] imx-gpc 20dc000.gpc: Registered imx-gpc
[ 0.119315] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.119845] vgaarb: loaded
[ 0.120603] SCSI subsystem initialized
[ 0.121059] usbcore: registered new interface driver usbfs
[ 0.121149] usbcore: registered new interface driver hub
[ 0.121254] usbcore: registered new device driver usb
[ 0.121937] i2c-gpio i2c@0: using pins 80 (SDA) and 62 (SCL)
[ 0.122931] i2c i2c-1: IMX I2C adapter registered
[ 0.122972] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.130230] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.220546] i2c i2c-2: IMX I2C adapter registered
[ 0.220583] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.221301] i2c i2c-3: IMX I2C adapter registered
[ 0.221340] i2c i2c-3: can't use DMA, using PIO instead.
[ 0.221503] Linux video capture interface: v2.00
[ 0.221571] pps_core: LinuxPPS API ver. 1 registered
[ 0.221594] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.221645] PTP clock support registered
[ 0.249641] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F)
[ 0.279632] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F)
[ 0.280551] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed ipu1
[ 0.280598] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0a
[ 0.280714] MIPI CSI2 driver module loaded
[ 0.280901] Advanced Linux Sound Architecture Driver Initialized.
[ 0.282701] clocksource: Switched to clocksource mxc_timer1
[ 0.282833] VFS: Disk quotas dquot_6.6.0
[ 0.282911] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.293044] NET: Registered protocol family 2
[ 0.293672] TCP established hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.293842] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.294113] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.294217] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.294319] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.294568] NET: Registered protocol family 1
[ 0.295028] RPC: Registered named UNIX socket transport module.
[ 0.295061] RPC: Registered udp transport module.
[ 0.295083] RPC: Registered tcp transport module.
[ 0.295104] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.295905] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 countee
[ 0.297643] Bus freq driver module loaded
[ 0.299465] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 0.305867] NFS: Registering the id_resolver key type
[ 0.305918] Key type id_resolver registered
[ 0.305941] Key type id_legacy registered
[ 0.305973] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.306540] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.306885] fuse init (API version 7.26)
[ 0.312948] bounce: pool size: 64 pages
[ 0.312985] io scheduler noop registered
[ 0.313008] io scheduler deadline registered
[ 0.313183] io scheduler cfq registered (default)
[ 0.315483] OF: PCI: host bridge /soc/pcie@0x01000000 ranges:
[ 0.315541] OF: PCI: IO 0x01f80000..0x01f8ffff -> 0x00000000
[ 0.315574] OF: PCI: MEM 0x01000000..0x01efffff -> 0x01000000
[ 0.371042] imx6q-pcie 1ffc000.pcie: Link: Gen2 disabled
[ 0.371080] imx6q-pcie 1ffc000.pcie: Link up, Gen1
[ 0.371324] imx6q-pcie 1ffc000.pcie: PCI host bridge to bus 0000:00
[ 0.371359] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.371388] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.371414] pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff]
[ 0.371865] PCI: bus0: Fast back to back transfers disabled
[ 0.402819] PCI: bus1: Fast back to back transfers disabled
[ 0.402868] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reg
[ 0.406881] PCI: bus2: Fast back to back transfers disabled
[ 0.406924] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reg
[ 0.407002] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reg
[ 0.407079] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reg
[ 0.407445] PCI: bus3: Fast back to back transfers enabled
[ 0.407501] pci_bus 0000:03: [bus 03] partially hidden behind bridge 0000:01]
[ 0.407847] PCI: bus4: Fast back to back transfers enabled
[ 0.407898] pci_bus 0000:04: [bus 04] partially hidden behind bridge 0000:01]
[ 0.408232] PCI: bus5: Fast back to back transfers enabled
[ 0.408282] pci_bus 0000:05: [bus 05] partially hidden behind bridge 0000:01]
[ 0.408360] pci_bus 0000:02: [bus 02-05] partially hidden behind bridge 0000]
[ 0.408406] pci 0000:00:00.0: bridge has subordinate 01 but max busn 05
[ 0.409036] pci 0000:00:00.0: BAR 0: assigned [mem 0x01000000-0x010fffff]
[ 0.409077] pci 0000:00:00.0: BAR 8: assigned [mem 0x01100000-0x013fffff]
[ 0.409107] pci 0000:00:00.0: BAR 9: assigned [mem 0x01400000-0x015fffff pre]
[ 0.409146] pci 0000:00:00.0: BAR 6: assigned [mem 0x01600000-0x0160ffff pre]
[ 0.409185] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.409216] pci 0000:01:00.0: BAR 8: assigned [mem 0x01100000-0x012fffff]
[ 0.409244] pci 0000:01:00.0: BAR 9: assigned [mem 0x01400000-0x015fffff 64b]
[ 0.409282] pci 0000:01:00.0: BAR 0: assigned [mem 0x01300000-0x01303fff]
[ 0.409328] pci 0000:01:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.409361] pci 0000:02:01.0: BAR 8: assigned [mem 0x01100000-0x012fffff]
[ 0.409388] pci 0000:02:01.0: BAR 9: assigned [mem 0x01400000-0x015fffff 64b]
[ 0.409424] pci 0000:02:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.409451] pci 0000:02:01.0: PCI bridge to [bus 03]
[ 0.409486] pci 0000:02:01.0: bridge window [io 0x1000-0x1fff]
[ 0.409536] pci 0000:02:01.0: bridge window [mem 0x01100000-0x012fffff]
[ 0.409579] pci 0000:02:01.0: bridge window [mem 0x01400000-0x015fffff 64b]
[ 0.409645] pci 0000:02:02.0: PCI bridge to [bus 04]
[ 0.409740] pci 0000:02:03.0: PCI bridge to [bus 05]
[ 0.409834] pci 0000:01:00.0: PCI bridge to [bus 02-05]
[ 0.409866] pci 0000:01:00.0: bridge window [io 0x1000-0x1fff]
[ 0.409915] pci 0000:01:00.0: bridge window [mem 0x01100000-0x012fffff]
[ 0.409957] pci 0000:01:00.0: bridge window [mem 0x01400000-0x015fffff 64b]
[ 0.410021] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.410045] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 0.410071] pci 0000:00:00.0: bridge window [mem 0x01100000-0x013fffff]
[ 0.410097] pci 0000:00:00.0: bridge window [mem 0x01400000-0x015fffff pre]
[ 0.410395] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.410428] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.410454] pci 0000:02:01.0: Signaling PME through PCIe PME interrupt
[ 0.410478] pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
[ 0.410502] pci 0000:02:03.0: Signaling PME through PCIe PME interrupt
[ 0.410928] pcieport 0000:01:00.0: enabling device (0140 -> 0143)
[ 0.411823] pcieport 0000:02:01.0: enabling device (0140 -> 0143)
[ 0.415591] backlight supply power not found, using dummy regulator
[ 0.418545] 20e0000.hdmi_video supply HDMI not found, using dummy regulator
[ 0.420525] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:01
[ 0.420585] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[ 0.420708] mxc_sdc_fb fb@0: registered mxc display driver hdmi
[ 0.437747] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,z
[ 0.462782] imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2)
[ 0.496665] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,z
[ 0.545099] Console: switching to colour frame buffer device 240x67
[ 0.580329] mxc_sdc_fb fb@1: mxcfb1 is turned off!
[ 0.580486] mxc_sdc_fb fb@2: mxcfb2 is turned off!
[ 0.580631] mxc_sdc_fb fb@3: mxcfb3 is turned off!
[ 0.582516] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.583237] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 0.587921] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 0.588751] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 0.588856] pfuze100-regulator 2-0008: pfuze100 found.
[ 0.614049] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 30, base_baud =X
[ 0.623317] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 1.974333] console [ttymxc0] enabled
[ 1.975340] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 80, base_baud =X
[ 1.975897] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 81, base_baud =X
[ 1.976436] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 82, base_baud =X
[ 1.977368] [drm] Initialized
[ 1.977780] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.987688] brd: module loaded
[ 1.988961] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 1.994177] loop: module loaded
[ 1.995436] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, usin4
[ 1.995445] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, usi0
[ 1.995453] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, u0
[ 1.995460] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 00
[ 1.998909] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[ 1.998939] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0xe
[ 1.998951] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp
[ 2.000302] scsi host0: ahci-imx
[ 2.000616] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x9
[ 2.003115] spi_imx 2008000.ecspi: probed
[ 2.004201] spi_imx 200c000.ecspi: probed
[ 2.005016] libphy: Fixed MDIO Bus: probed
[ 2.005411] vcan: Virtual CAN interface driver
[ 2.005417] CAN device driver interface
[ 2.005726] 2090000.flexcan supply xceiver not found, using dummy regulator
[ 2.006575] flexcan 2090000.flexcan: device registered (reg_base=e77fc000, i)
[ 2.006756] 2094000.flexcan supply xceiver not found, using dummy regulator
[ 2.007434] flexcan 2094000.flexcan: device registered (reg_base=e7804000, i)
[ 2.008601] 2188000.ethernet supply phy not found, using dummy regulator
[ 2.023132] pps pps0: new PPS source ptp0
[ 2.025663] libphy: fec_enet_mii_bus: probed
[ 2.027302] fec 2188000.ethernet eth0: registered PHC device 0
[ 2.027816] usbcore: registered new interface driver asix
[ 2.027870] usbcore: registered new interface driver ax88179_178a
[ 2.027910] usbcore: registered new interface driver cdc_ether
[ 2.027951] usbcore: registered new interface driver net1080
[ 2.027988] usbcore: registered new interface driver cdc_subset
[ 2.028026] usbcore: registered new interface driver zaurus
[ 2.028089] usbcore: registered new interface driver cdc_ncm
[ 2.028093] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.028096] ehci-pci: EHCI PCI platform driver
[ 2.028160] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 2.028350] usbcore: registered new interface driver usb-storage
[ 2.028444] usbcore: registered new interface driver usbserial
[ 2.028482] usbcore: registered new interface driver usbserial_generic
[ 2.028516] usbserial: USB Serial support registered for generic
[ 2.028550] usbcore: registered new interface driver ftdi_sio
[ 2.028581] usbserial: USB Serial support registered for FTDI USB Serial Deve
[ 2.028612] usbcore: registered new interface driver pl2303
[ 2.028644] usbserial: USB Serial support registered for pl2303
[ 2.029913] 2184800.usbmisc supply vbus-wakeup not found, using dummy regular
[ 2.040592] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.040626] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 2.046020] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 2.062733] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.063541] hub 1-0:1.0: USB hub found
[ 2.063577] hub 1-0:1.0: 1 port detected
[ 2.064631] mousedev: PS/2 mouse device common for all mice
[ 2.074919] input: stmpe-ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i20
[ 2.078379] rtc-ds1307 1-0068: oscillator failed, set time!
[ 2.081182] rtc-ds1307 1-0068: rtc core: registered m41t0 as rtc0
[ 2.081768] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.1
[ 2.081899] i2c /dev entries driver
[ 2.083265] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[ 2.083416] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[ 2.084811] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 2.085471] sdhci: Secure Digital Host Controller Interface driver
[ 2.085474] sdhci: Copyright(c) Pierre Ossman
[ 2.085476] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.086603] sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed ste
[ 2.086649] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.152860] mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADA
[ 2.155414] sdhci-esdhc-imx 2194000.usdhc: could not get ultra high speed ste
[ 2.155455] sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
[ 2.232861] mmc2: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADA
[ 2.235537] sdhci-esdhc-imx 2198000.usdhc: could not get ultra high speed ste
[ 2.302792] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADA
[ 2.304142] mxc_vpu 2040000.vpu_fsl: VPU initialized
[ 2.304652] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) drived
[ 2.305924] caam 2100000.caam: ERA source: CAAMVID.
[ 2.306058] caam 2100000.caam: AXI pipeline throttling enabled.
[ 2.306936] caam 2100000.caam: Entropy delay = 3200
[ 2.367725] caam 2100000.caam: Instantiated RNG4 SH0
[ 2.392745] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.392781] ahci-imx 2200000.sata: no device found, disabling link.
[ 2.392787] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
[ 2.428485] caam 2100000.caam: Instantiated RNG4 SH1
[ 2.428495] caam 2100000.caam: device ID = 0x0a16010000000000 (Era 4)
[ 2.428501] caam 2100000.caam: job rings = 2, qi = 0
[ 2.436497] caam algorithms registered in /proc/crypto
[ 2.451718] caam_jr 2101000.jr0: registering rng-caam
[ 2.452721] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 2.452773] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-see
[ 2.452994] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.453150] usbcore: registered new interface driver usbhid
[ 2.453152] usbhid: USB HID core driver
[ 2.492736] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.508326] random: fast init done
[ 2.682824] stmpe-adc stmpe-adc: Initialized
[ 2.731278] sgtl5000 2-000a: sgtl5000 revision 0x11
[ 2.745490] hub 1-1:1.0: USB hub found
[ 2.752933] hub 1-1:1.0: 4 ports detected
[ 2.752971] mmc0: new DDR MMC card at address 0001
[ 2.753462] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[ 2.753668] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[ 2.753866] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[ 2.765256] mmcblk0: p1 p2
[ 3.074880] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 3.085627] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 3.186115] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 3.202740] usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
[ 3.219708] imx-sgtl5000 sound: sgtl5000 <-> 2028000.ssi mapping ok
[ 3.236682] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mappik
[ 3.240210] imx-audio-hdmi sound-hdmi: hdmi-hifi.0 <-> soc:hdmi_audio@001200k
[ 3.241516] NET: Registered protocol family 10
[ 3.242514] NET: Registered protocol family 17
[ 3.242529] can: controller area network core (rev 20120528 abi 9)
[ 3.242684] NET: Registered protocol family 29
[ 3.242743] can: raw protocol (rev 20120528)
[ 3.242748] can: broadcast manager protocol (rev 20161123 t)
[ 3.242759] can: netlink gateway (rev 20130117) max_hops=1
[ 3.243094] Key type dns_resolver registered
[ 3.245291] cpu cpu0: Registered imx6q-cpufreq
[ 3.245318] Registering SWP/SWPB emulation handler
[ 3.257676] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperatureC
[ 3.258936] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 3.260731] rtc-ds1307 1-0068: hctosys: unable to read the hardware clock
[ 3.261465] usb_otg_vbus: disabling
[ 3.261482] ALSA device list:
[ 3.261486] #0: imx6q-apalis-sgtl5000
[ 3.261488] #1: imx-spdif
[ 3.261491] #2: imx-hdmi-soc
[ 3.391789] hub 1-1.1:1.0: USB hub found
[ 3.399466] hub 1-1.1:1.0: 4 ports detected
[ 3.503502] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesysm
[ 3.515262] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.838741] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 3.849533] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[ 3.859030] EXT4-fs (mmcblk0p2): recovery complete
[ 3.882086] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. )
[ 3.898149] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.911805] devtmpfs: mounted
[ 3.920286] Freeing unused kernel memory: 1024K
[ 4.079415] systemd[1]: System time before build time, advancing clock.
[ 4.135870] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SE)
[ 4.170425] systemd[1]: Detected architecture arm.
Welcome to The �Ångstr�öm Distribution v2017.12!
[ 4.203341] systemd[1]: Set hostname to <apalis-imx6>.
[ 4.463612] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.503155] systemd[1]: Started Forward Password Requests to Wall Directory .
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.542982] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.583509] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.638563] systemd[1]: Starting Load Kernel Modules...
[ 4.676717] systemd[1]: Mounting Kernel Debug File System...
[ 4.688511] galcore: loading out-of-tree module taints kernel.
[ 4.696120] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.713229] Galcore version 6.2.2.93313
Starting Create list of required st��…ce nodes for the current kernel..
[ OK ] Created slice system-getty.slice.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on Network Service Netlink Socket.
Starting File System Check on Root Device...
[ OK ] Reached target Swap.
Mounting Temporary Directory (/tmp)...
Starting Export GPIOs to user space...
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Journal Socket (/dev/log).
Starting Journal Service...
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of required sta��…vice nodes for the current kerne.
[ OK ] Started File System Check on Root Device.
[ OK ] Started Export GPIOs to user space.
Starting Remount Root and Kernel File Systems...
[ 5.293062] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Remount Root and Kernel File Systems.
Starting Create Static Device Nodes in /dev...
Starting udev Coldplug all Devices...
[ OK ] Started Journal Service.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Starting udev Kernel Device Manager...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted /var/volatile.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load Kernel Modules.
Starting Apply Kernel Variables...
Mounting Kernel Configuration File System...
Mounting FUSE Control File System...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Load/Save Random Seed.
[ 6.001344] systemd-journald[230]: Received request to flush runtime journal1
[ 6.036796] systemd-journald[230]: File /var/log/journal/257e330e4fe946c898e.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight��…ightness of backlight:backlight..
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Found device /dev/ttymxc0.
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Started Create Volatile Files and Directories.
[ 6.444307] adv7280 3-0021: chip found @ 0x42 (21a8000.i2c)
[ 6.453199] adv7280 3-0021: no sensor pwdn pin available
[ 6.496785] adv7280 3-0021: adv7280_probe:Analog Device adv7280 not detected!
[ OK ] Reached target Sound Card.
[ 6.575752] max9526 3-0020: Device seems not to be a MAX9526
[ 6.592667] ov564x_mipi 3-003c: found pwm2, period=0
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ 6.843160] ov5640_read_reg:write reg error:reg=300a
[ 6.851624] camera ov5640_mipi is not found
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ 7.178780] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 7.180619] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 7.183009] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
Starting sshd.socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 7.422613] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on sshd.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Telephony service...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 7.902845] Loading modules backported from Linux version v4.14-0-gbebc608
[ 7.912229] Backport generated by backports.git v4.14-rc2-1-34-g1d8cc15
[ OK ] Started Telephony service.
[ 7.939254] Bluetooth: Core ver 2.22
[ 7.945507] NET: Registered protocol family 31
[ 7.952459] Bluetooth: HCI device and connection manager initialized
[ 7.961347] Bluetooth: HCI socket layer initialized
[ 7.968695] Bluetooth: L2CAP socket layer initialized
[ 7.976221] Bluetooth: SCO socket layer initialized
Starting Connection service...
Starting Login Service...
Starting Save/Restore Sound Card State...
Starting Load default USB gadget schema g1.schema...
[ OK ] Reached target Containers.
[ 8.143677] using random self ethernet address
[ 8.150589] using random host ethernet address
[ OK ] Started Timestamping service.
Starting RPC Bind Service...
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started RPC Bind Service.
[ 8.304842] Micrel KSZ9031 Gigabit PHY 2188000.ethernet-1:07: attached PHY d)
[ 8.326451] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] Started Connection service.
[ OK ] Started Login Service.
[ 8.426441] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 8.436285] usb0: MAC 00:14:2d:ff:ff:ff
Starting Hostname Service...
Starting WPA supplicant...
[ OK ] Started Load default USB gadget schema g1.schema.
Starting Network Service...
[ OK ] Started WPA supplicant.
[ OK ] Started Network Service.
[ 8.615714] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ OK ] Started Hostname Service.
[ 8.664108] configfs-gadget gadget: high-speed config #1: c
[ 8.672205] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ OK ] Reached target Network.
Starting Permit User Sessions...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
[ OK ] Started LXDE Display Manager.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 9.231434] vgaarb: this pci device is not a vga device
[ 9.299199] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 9.373468] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 9.439574] vgaarb: this pci device is not a vga device
[ 9.452680] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
[ 9.533204] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,z
.---O---.
| | .-. o o
| | | __ | ---'| '--.| .-'| | |
The Angstrom Distribution apalis-imx6 ttymxc0
Angstrom v2017.12 - Kernel
Apalis-iMX6_LXDE-Image 2.8b3.111 20180626
apalis-imx6 login: [ 10.370220] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 96,16,48z
Toradex Easy Installer output:
michael@michael-VirtualBox:~/Apalis-iMX6_ToradexEasyInstaller_1.7-20180731$ ./recovery-linux.sh
Downloading Toradex Easy Installer...
Could not open device vid=0x1b67 pid=0x4000
Downloading Toradex Easy Installer failed...
