I am trying to change debug serial console from default UART A to UART C in U-Boot V2.7. Here is a script that worked for U-Boot old version (V2.6 or V2.5).
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c
index 50d1d1f..db20faa 100644
--- a/board/toradex/colibri_imx6/colibri_imx6.c
+++ b/board/toradex/colibri_imx6/colibri_imx6.c
@@ -86,11 +86,19 @@ int dram_init(void)
return 0;
+#if 0
/* Colibri UARTA */
iomux_v3_cfg_t const uart1_pads[] = {
MX6_PAD_CSI0_DAT10__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
+#else
+/* Colibri UARTC */
+iomux_v3_cfg_t const uart3_pads[] = {
+ MX6_PAD_SD4_CLK__UART3_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
+ MX6_PAD_SD4_CMD__UART3_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
+#endif
#define PC MUX_PAD_CTRL(I2C_PAD_CTRL)
/* Colibri I2C */
@@ -272,7 +280,7 @@ static void setup_dtemode_uart(void)
static void setup_iomux_uart(void)
setup_dtemode_uart();
- imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
+ imx_iomux_v3_setup_multiple_pads(uart3_pads, ARRAY_SIZE(uart3_pads));
#ifdef CONFIG_USB_EHCI_MX6
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h
index f69c30c..921b354 100644
--- a/include/configs/colibri_imx6.h
+++ b/include/configs/colibri_imx6.h
@@ -38,7 +38,7 @@
#define CONFIG_MISC_INIT_R
#define CONFIG_MXC_UART
-#define CONFIG_MXC_UART_BASE UART1_BASE
+#define CONFIG_MXC_UART_BASE UART3_BASE
/* Make the HW version stuff available in u-boot env */
#define CONFIG_VERSION_VARIABLE /* ver environment variable */
@@ -153,7 +153,7 @@
/* allow to overwrite serial and ethaddr */
#define CONFIG_ENV_OVERWRITE
-#define CONFIG_CONS_INDEX 1
+#define CONFIG_CONS_INDEX 3
#define CONFIG_BAUDRATE 115200
/* Command definition */
I manually applied these changes in U-Boot V2.7 source code. In addition, I had to change defined value of “CONFIG_CONS_INDEX” from 1 to 3 in “u-boot-toradex/include/configs/mx6_common.h” file.
After the U-Boot is built and deployed, I don’t see any U-Boot console output at either UART A or UART C port. What am I missing or doing incorrectly?
Thank you
William
