I am trying to put this:
&pinctrl_ipu1_lcdif {
ipu1_lcdif_pins: ipu1-lcdif-pins {
fsl,pins = <
MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x58
into dts overlay for colibri imx6dl. I have also panel_dpi and backlight settings in the overlay and works fine, but after I add settings for pin drive strength I get error:
Error: …/colibri-imx6_800x600_overlay.dts:27.9-10 syntax error
this line is:
I try many different syntax which AI suggest, but I can’t get rid of error. Could someone give me how it should be.
Based on the syntax error you’re encountering, the issue is likely with the structure of your device tree overlay(1). Looking at the working examples from the Toradex documentation, here’s the correct syntax for adding pinctrl settings to a device tree overlay:
Correct Device Tree Overlay Structure
For Colibri iMX6 modules, your overlay should follow this pattern(2):
/dts-v1/;
/plugin/;
#include "linux/arch/arm/boot/dts/nxp/imx/imx6dl-pinfunc.h"
compatible = "toradex,colibri_imx6dl-eval-v3";
&iomuxc {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_my_pins>;
pinctrl_my_pins: my_muxgrp {
fsl,pins = <
(2)
Key Points to Check
- Include Headers: Make sure you have the correct include for pin function definitions(1)
- Compatible String: Ensure your compatible string matches your specific hardware(1)(3)
- Pin Group Structure: The pin group must be properly nested within the
&iomuxc node(2)
- Syntax: Each pin definition should be on its own line with proper spacing(2)
Template Structure
The general template for device tree overlays follows this pattern(3):
/dts-v1/;
/plugin/;
// Header file with pin definitions
#include <soc-pinfunc.h>
compatible = "toradex,apalis-imx8"; // Set hardware compatibility
&iomuxc {
pinctrl-0 = <&pinctrl-originally-in-device-tree>, <&pinctrl_my_pins>;
name-of-som {
fsl,pins = <
PIN_NAME_PIN_MUX PAD_CTRL // PINS
(3)
Make sure your overlay structure matches these examples, particularly the nesting of the pin group within the &iomuxc node and the proper syntax for the fsl,pins property.
Yes, this is solution:
#include “linux/arch/arm/boot/dts/nxp/imx/imx6dl-pinfunc.h”
but just like this:
#include <imx6dl-pinfunc.h>
Hello @medicalSpark,
Thanks for marking the solution here on the community.
If you run into other issues, please feel free to post again.
Bruno
