I’m unable to change the bus speed on I2C3. No matter what I do, it always runs at 85.84 KHz.
The following code is pretty mature, and has been used in other work. It was only while I was hunting down an I2C problem on a new project that I noticed the speed issue. The code first re-maps pins 88 and 92 for I2C3 functionality, and then sets the configInts. Note the speed setting to 400 KHz near the end. No matter what I change that number to, the result is always the same as above.
This is not a show-stopper; the thing is working fine. I’d like to speed it up because the device interrupts the CPU every 10 msec with new data, and right now the I2C stuff actually takes up quite a lot of CPU time.
Any idea what I may be doing wrong or if this is a defect in the I2C library?
bool I2Cdev::bI2C_Init(void) //ok//
DWORD dwIRq;
bool bSuccess = false;
tVersion ver;
BOOL result;
// set default values
dwI2C_Adr = I2C_ADR; // I2C address of the IMU chip
dwINT_Pin = INT_PIN; // pin for Int
dwINT_Sig_Lvl = INT_SIG_LVL; // Int signal invertetd
dwHwAdaptPrio = HWADAPTPRIO; // Task priority
uIo IntIo = COLIBRI_PIN(dwINT_Pin);
g_hi2c =I2c_Init(L"I2C3");
uIo i2cSclPin;
i2cSclPin.ColibriPin.Tp = ioColibriPin;
i2cSclPin.ColibriPin.Nr = 88;
result = I2c_SetConfigInt(g_hi2c, L"ioScl", i2cSclPin.GenericDefinition, StoreVolatile);
if (result == false)
DEBUGMSG(ZONE_ERROR,(TEXT("IMU driver:Failed to set config int for ioScl\r\n")));
return false;
uIo i2cSdaPin;
i2cSdaPin.ColibriPin.Tp = ioColibriPin;
i2cSdaPin.ColibriPin.Nr = 92;
result = I2c_SetConfigInt(g_hi2c, L"ioSda", i2cSdaPin.GenericDefinition, StoreVolatile);
DEBUGMSG(ZONE_ERROR,(TEXT("IMU driver:Failed to set config int for ioSda\r\n")));
return false;
I2c_Open(g_hi2c);
if (g_hi2c == NULL)
DEBUGMSG(ZONE_INFO,(TEXT("IMU driver: failed to open I2C handle\r\n")));
return false;
HANDLE gpioHandle = Gpio_Init(L"SOFTWARE\\Toradex\\gpio");
result = Gpio_SetConfigString(gpioHandle, i2cSclPin, NULL, L"altfn=6,sion=force", StoreVolatile);
DEBUGMSG(ZONE_ERROR,(TEXT("IMU driver:Failed Gpio_SetConfigString altfn=6\r\n")));
return false;
result = Gpio_SetConfigString(gpioHandle, i2cSdaPin, NULL, L"altfn=1,sion=force", StoreVolatile);
DEBUGMSG(ZONE_ERROR,(TEXT("IMU driver:Failed Gpio_SetConfigString altfn=1\r\n")));
return false;
I2c_SetConfigInt(g_hi2c, L"BitRateHz", 400000, StoreVolatile); // Set I2C speed to 400KHz
I2c_SetConfigInt(g_hi2c, L"SlaveAddrSize", 7, StoreVolatile); // Set 7 bit Slave address
I2c_SetConfigInt(g_hi2c, L"SlaveAddr", dwI2C_Adr, StoreVolatile); // Set Slave address
I2c_SetConfigInt(g_hi2c, L"RegisterAddrSize", 8, StoreVolatile); // 8 bit Register address to send
//I2c_SetConfigInt(g_hi2c, L"RegisterAddrLE", 1 ,StoreVolatile); // Little endian.
