Can't read partition table on 1:0
Dear community,
I tried to perform flashing of Colibri iMX6 module with no success.
Once inserted SD card, I sent the command “run setupdate” from U-Boot prompt but the partition is is not recognized correctly.
Colibri iMX6 # run setupdate
** Can’t read partition table on 1:0 **
** Invalid partition 1 **
Do you have any idea on the cause of the problem?
Thank you
Hi
I’ve sometimes see such error messages when changing SD cards when U-Boot is running.
Do you have the same error when you insert the SD card and power cycle?
Does you’re SD card have a strange partitioning? E.g. when you boot the Colibri iMX6 to Linux where does the card get mounted and the installation files are visible on /media/mmcblk1p1?
What is the output of mount | grep mmcblk1
Max
Hi Max,
thank you for your help.
I confirm that message is a bit different if I power cycle with SD inserted (see below)
*Colibri iMX6 # run setupdate
** Invalid partition 1 ***
After boot the card get mounted on /media/mmcblk1
The output of “mount | grep mmcblk1” is
colibri-imx6:~# mount | grep mmcblk1
/dev/mmcblk1 on /media/mmcblk1 type vfat (rw,relatime,gid=6,fmask=0007,dmask=00)
Regards
Max,
Problem solved with new SD partitioning.
I noticed that the SD was mounted on mmcblk1 instead of mmcblk1p1.
Thank you.
