I have been using iMX6S modules using linux for a while now and never had a problem until now. I was flashing a fresh image made with yocto and everything was OK, made “run update” and began to flash everything, last line was “resetting …” which was weird because the board resets itself after that line.
I powercycled the board but never got uboot to load.
Then I followed the instructions to enter recovery mode, and flashed an official Toradex linux image (V2.6), the output was similar: “resetting …” but can’t get to load uboot. I even flashed uboot only (run update_uboot) but never got uboot to load afterwards.
Can this be a hardware problem?
Hardware used:
Col iMX6s IT V1.0B
Iris Rev 1.1
12V PC (ATX) Power Supply … I’m blaming this because was the only thing I changed from previous setups.
Thanks for your help.
