However, now the touch isn’t working. Can you confirm that this looks correct?
I’m running the touch calibrator and not able to use touch at all. This is the output:
Last login: Fri Jun 9 18:25:15 2023 from 10.0.0.22
** WARNING **
THIS DEVICE IS IN ENGINEERING MODE
torizon@verdin-imx8mp-14762939:~$ docker run -ti --rm -e ACCEPT_FSL_EULA=1 --privileged -v /dev:/dev -v /run/udev/:/run/udev/ -v /etc/udev/rules.d:/etc/udev/rules.d torizon/weston-touch-calibrator:$CT_TAG_WESTON_TOUCH_CALIBRATOR
NXP EULA has already been accepted.
Date: 2023-06-09 UTC
[18:32:21.731] weston 9.0.0
https://wayland.freedesktop.org
Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
Build: 9.0.0
[18:32:21.731] Command line: /usr/bin/weston
[18:32:21.731] OS: Linux, 5.4.193-5.7.2+git.b60d3160fd04, #1-TorizonCore SMP PREEMPT Fri Dec 23 15:47:24 UTC 2022, aarch64
[18:32:21.731] warning: XDG_RUNTIME_DIR "/tmp/weston-xdg" is not configured
correctly. Unix access mode must be 0700 (current mode is 755),
and must be owned by the user (current owner is UID 0).
Refer to your distribution on how to get it, or
http://www.freedesktop.org/wiki/Specifications/basedir-spec
on how to implement it.
[18:32:21.732] Using config file '/etc/xdg/weston/weston.ini'
[18:32:21.732] Output repaint window is 7 ms maximum.
[18:32:21.732] Loading module '/usr/lib/aarch64-linux-gnu/libweston-9/drm-backend.so'
[18:32:21.739] initializing drm backend
[18:32:21.740] logind: not running in a systemd session
[18:32:21.740] logind: cannot setup systemd-logind helper (-61), using legacy fallback
[18:32:21.743] using /dev/dri/card0
[18:32:21.743] DRM: supports atomic modesetting
[18:32:21.743] DRM: does not support GBM modifiers
[18:32:21.743] DRM: supports picture aspect ratio
[18:32:21.743] Loading module '/usr/lib/aarch64-linux-gnu/libweston-9/gl-renderer.so'
[18:32:21.751] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_KHR_platform_wayland
EGL_EXT_platform_wayland EGL_KHR_platform_gbm
[18:32:21.754] EGL version: 1.5
[18:32:21.754] EGL vendor: Vivante Corporation
[18:32:21.754] EGL client APIs: OpenGL_ES OpenVG
[18:32:21.754] EGL extensions: EGL_KHR_fence_sync EGL_KHR_reusable_sync
EGL_KHR_wait_sync EGL_KHR_image EGL_KHR_image_base
EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image
EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image
EGL_EXT_image_dma_buf_import
EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_lock_surface
EGL_KHR_create_context EGL_KHR_no_config_context
EGL_KHR_surfaceless_context EGL_KHR_get_all_proc_addresses
EGL_EXT_create_context_robustness EGL_EXT_protected_surface
EGL_EXT_protected_content EGL_EXT_buffer_age
EGL_ANDROID_native_fence_sync EGL_WL_bind_wayland_display
EGL_WL_create_wayland_buffer_from_image EGL_KHR_partial_update
EGL_EXT_swap_buffers_with_damage
EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float
[18:32:21.755] EGL_KHR_surfaceless_context available
[18:32:21.758] GL version: OpenGL ES 3.1 V6.4.3.p1.305572
[18:32:21.759] GLSL version: OpenGL ES GLSL ES 3.10
[18:32:21.759] GL vendor: Vivante Corporation
[18:32:21.759] GL renderer: Vivante GC7000UL
[18:32:21.759] GL extensions: GL_OES_vertex_type_10_10_10_2
GL_OES_vertex_half_float GL_OES_element_index_uint
GL_OES_mapbuffer GL_OES_vertex_array_object
GL_OES_compressed_ETC1_RGB8_texture
GL_OES_compressed_paletted_texture GL_OES_texture_npot
GL_OES_rgb8_rgba8 GL_OES_depth_texture
GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32
GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap
GL_OES_get_program_binary GL_OES_fragment_precision_high
GL_OES_standard_derivatives GL_OES_EGL_image
GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3
GL_OES_EGL_sync GL_OES_texture_stencil8
GL_OES_shader_image_atomic
GL_OES_texture_storage_multisample_2d_array
GL_OES_required_internalformat GL_OES_surfaceless_context
GL_OES_draw_buffers_indexed GL_OES_texture_border_clamp
GL_OES_texture_buffer GL_OES_texture_cube_map_array
GL_OES_draw_elements_base_vertex GL_OES_texture_half_float
GL_OES_texture_float GL_KHR_blend_equation_advanced
GL_KHR_debug GL_KHR_robustness
GL_KHR_robust_buffer_access_behavior
GL_EXT_texture_type_2_10_10_10_REV
GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888
GL_EXT_texture_compression_s3tc GL_EXT_read_format_bgra
GL_EXT_multi_draw_arrays GL_EXT_frag_depth
GL_EXT_discard_framebuffer GL_EXT_blend_minmax
GL_EXT_multisampled_render_to_texture
GL_EXT_color_buffer_half_float GL_EXT_color_buffer_float
GL_EXT_robustness GL_EXT_texture_sRGB_decode
GL_EXT_draw_buffers_indexed GL_EXT_texture_border_clamp
GL_EXT_texture_buffer GL_EXT_texture_cube_map_array
GL_EXT_multi_draw_indirect GL_EXT_draw_elements_base_vertex
GL_EXT_texture_rg GL_EXT_protected_textures GL_EXT_sRGB
GL_VIV_direct_texture
[18:32:21.759] GL ES 2 renderer features:
read-back format: BGRA
wl_shm sub-image to texture: yes
EGL Wayland extension: yes
[18:32:21.770] event2 - Webcam C110: Webcam C110: is tagged by udev as: Keyboard
[18:32:21.770] event2 - Webcam C110: Webcam C110: device is a keyboard
[18:32:21.772] event1 - gpio-keys: is tagged by udev as: Keyboard
[18:32:21.773] event1 - gpio-keys: device is a keyboard
[18:32:21.776] event0 - 30370000.snvs:snvs-powerkey: is tagged by udev as: Keyboard
[18:32:21.776] event0 - 30370000.snvs:snvs-powerkey: device is a keyboard
[18:32:21.793] libinput: configuring device "Webcam C110: Webcam C110".
[18:32:21.793] libinput: configuring device "gpio-keys".
[18:32:21.793] libinput: configuring device "30370000.snvs:snvs-powerkey".
[18:32:21.794] DRM: head 'DSI-1' found, connector 35 is connected, EDID make 'unknown', model 'unknown', serial 'unknown'
[18:32:21.794] Registered plugin API 'weston_drm_output_api_v1' of size 24
[18:32:21.794] Registered plugin API 'weston_drm_virtual_output_api_v1' of size 48
[18:32:21.796] Chosen EGL config details: id: 41 rgba: 8 8 8 0 buf: 24 dep: 0 stcl: 0 int: 1-60 type: win|pix|pbf|swap_preserved vis_id: XRGB8888 (0x34325258)
[18:32:21.796] Output DSI-1 (crtc 33) video modes:
1280x800@58.5, preferred, current, 69.3 MHz
[18:32:21.796] associating input device event2 with output DSI-1 (none by udev)
[18:32:21.796] associating input device event1 with output DSI-1 (none by udev)
[18:32:21.796] associating input device event0 with output DSI-1 (none by udev)
[18:32:21.796] Output 'DSI-1' enabled with head(s) DSI-1
[18:32:21.796] Compositor capabilities:
arbitrary surface rotation: yes
screen capture uses y-flip: yes
presentation clock: CLOCK_MONOTONIC, id 1
presentation clock resolution: 0.000000001 s
[18:32:21.797] Loading module '/usr/lib/aarch64-linux-gnu/weston/desktop-shell.so'
[18:32:21.798] launching '/usr/lib/aarch64-linux-gnu/weston-keyboard'
[18:32:21.803] Loading module '/usr/lib/aarch64-linux-gnu/libweston-9/xwayland.so'
[18:32:21.822] Registered plugin API 'weston_xwayland_v1' of size 32
[18:32:21.822] Registered plugin API 'weston_xwayland_surface_v1' of size 16
[18:32:21.822] xserver listening on display :0
[18:32:21.823] launching '/usr/lib/aarch64-linux-gnu/weston-desktop-shell'
could not load cursor 'dnd-move'
could not load cursor 'dnd-copy'
could not load cursor 'dnd-none'
weston-touch-calibrator error: ":0" was not found.
I followed the rest of the instructions and it looks like my only connector is “DSI-1”:
root@56fd19ec4e03:/home/torizon# modetest -M imx-drm
Encoders:
id crtc type possible crtcs possible clones
34 33 DSI 0x00000001 0xffffffff
Connectors:
id encoder status name size (mm) modes encoders
35 34 connected DSI-1 217x136 1 34
modes:
index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
#0 1280x800 58.48 1280 1340 1380 1440 800 807 816 823 69300 flags: ; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
flags: immutable range
values: 0 1
value: 0
4 TILE:
blobs:
value:
CRTCs:
id fb pos size
33 36 (0,0) (1280x800)
props:
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
31 33 36 0,0 0,0 0 0x00000001
formats: XR24 AR24 RG16 XB24 AB24 AR15 XR15
props:
8 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
32 zpos:
values: 0 0
value: 0
Frame buffers:
id size pitch
Although I don’t know why specifying a display connector would help. Now when I run the calibrator it ends with the error:
weston-touch-calibrator error: "DSI-1" was not found.
The desktop does display on the screen by the way, but there is no calibrator tool. It displayed whether I specified a DISPLAY in the docker command or not.
