Dear Mr Ziswiler,
I`m trying to update the device tree using BSP image: Apalis_T30_LinuxImageV2.6Beta1_20160331, Debian Jessie rootfs and 4.6.2 kernel on my apalis T 30 + Apalis Evaluation Board V1.1A. I have successfully downloaded and compiled mainline linux kernel 4.6.2 with commands:
wget https://cdn.kernel.org/pub/linux/kernel/v4.x/linux-4.6.2.tar.xz
tar -vxf linux-4.6.2.tar.xz
cd linux-4.6.2
export ARCH=arm
export PATH=/home/kamil/Downloads/apalis/gcc-linaro/bin/:$PATH
export CROSS_COMPILE=arm-linux-gnueabihf-
make tegra_defconfig
make -j6 uImage LOADADDR=0x82008000
make -j6 dtbs
make -j6 modules
cp arch/arm/boot/dts/tegra30-apalis* /media/kamil/6537-3463/apalis_t30/
But, when I`m trying to update device tree I cannot see any error message, apart from the info: 0 bytes written
U-Boot SPL 2015.04 (Mar 31 2016 - 01:18:13)
U-Boot 2015.04 (Mar 31 2016 - 01:18:13)
TEGRA30
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x2000000-0x2010000
tegra-pcie: non-prefetchable memory: 0x20000000-0x30000000
tegra-pcie: prefetchable memory: 0x30000000-0x40000000
tegra-pcie: 4x1, 1x2 configuration
tegra-pcie: probing port 2, using 1 lanes
In: serial
Out: lcd
Err: lcd
Model: Toradex Apalis T30 2GB V1.0E, Serial# 02650732
Net: e1000: no NVM
e1000#0
Apalis T30 # run setupdate
reading flash_blk.img
710 bytes read in 13 ms (52.7 KiB/s)
## Executing script at 81000000
reading apalis_t30/flash_blk.img
4029 bytes read in 21 ms (186.5 KiB/s)
## Executing script at 80408000
enter "run update" to update the entire module
Apalis T30 # run update_fdt
reading apalis_t30/tegra30-apalis-eval.dtb
29450 bytes read in 32 ms (898.4 KiB/s)
writing 730a
0 bytes written
Apalis T30 #
