Cannot import QtGuid4.dll on iMX7
we are working with the Colibri T20 Module, WEC7 and Qt 4.8.4 provided by toradex (http://developer.toradex.com/knowledge-base/qt-on-the-toradex-modules#Patching_QT_SDK_to_use_newer_Toradex_SDKs) . Now I’d like to run the same project on a iMX7D. The project compiles correctly. but when I try to run it, I’m getting a errormessage: “Unable to import libraray QtGuid4.dll ! Program exit.”. I’ve copied all the Qt dll to “/FlashDisk/System/” and the executing directory inkl. the msvcr90d.dll.
Is it possible to run the same project on the iMX7 on a WEC7?
Kind Regards, Dominik
@dominikh: Which QT did you have installed on your system? For IMX7 you need to go for the one without QT. See also the two links on the QT install instructions.
@samuel.tx: Thanks. Didn’t know that.
@dominikh: You can build your application with the CE6 SDK and let it run under CE 7 without any issue. You could also use the CE 6 version with a CE 7 SDK probably, but we never tried that.
@samuel.tx: I used the one with opengl, since I could not add the other version to visual studio. The patch only works for CE6. Is it possible to use the Version without OpenGL with WinCE7?
Hello @samuel.tx,
I have the same problem with Colibri imx7 but building the application with CE6 SDK didn’t solve the problem.
Can you suggest me the Solution?
Hello @dominikh,
Can you suggest me how you resolved the issue?
Thank you,
@samuel.tx @dominikh.
Dear @sri406,
Same questions posted here : https://www.toradex.com/community/questions/38060/running-qt-application-in-colibri-imx7-giving-erro.html, we would like to do follow up there.
