We’re trying to access our SPI device driver for a Colibri i.MX7D. When looking in /dev, on the device, the SPI driver is not listed as one of the drivers in the device tree. I found a similar community forum post to this one regarding the issue where someone had a similar question to this about a Colibri i.MX7 board:
The post mentioned that in order for the SPI driver to work the CAN driver needs to be disabled. There’s also a link to imx7-colibri-eval-v3.dtsi that opens the file in the section where the modification is needed.
What exactly must be done to the file?
In the spidev0: spidev@0 section there is the line: status = “disabled”. Does this just need to be changed to status = “enabled”? I’ve viewed the spi-imx.c file and it appears that the spi_imx_dt_ids structure is defined and setup properly, but I don’t see spi anywhere in the /dev folder on our device. I’ve rebuilt the imx7-colibri-eval-v3.dtsi file and copied the corresponding imx7d-colibri-eval-v3.dtb file, after modification, to the device but I still don’t see the spi driver in the list of devices.
Thank you sanchayan.tx! This is exactly what we needed to make this work. spidev is now showing up in /dev when the embedded Linux OS is loaded.
Is there a document somewhere on your website that specifies the function calls that we must make from user space in an application to access the spi-imx device driver to read from and write to a device? Function calls like open() and ioctl(). I’m not familiar with embedded Linux device drivers, but do have familiarity with Windows CE and vxworks.
Is there a document somewhere on your website that describes how to make the calls to access the SPI device driver?
