Cannot enter recovery mode on Apalis iMX6 with Ixora board
I just got an Apalis iMX6 with Ixora dev board.
First I installed an embedded Linux OS on it from the Toradex options.
But afterwards I discovered that I want to install a different OS on the device
I tried entering recovery mode by shortening the pins on the board as described in the Toradex website but it doesn’t work.
I removed the JP2 connector, connected the board to the PC, shortened the wires and powered the board on. Waited more than 6 seconds and when I restart the device afterwards it still loads the OS that I previously installed.
Is there something that I am missing or a different way to flash a new OS on the device?
Hello @Svetoslav ,
After you have entered the recovery mode (by shorting the pins and powering on the module ) do not reboot the module. Doing so will result in a normal boot.
Instead, connect the USB cable from the PC to the OTG port of the board, and in the PC start the recovery script that you can download here:
After that the module will reboot and you will be able to connect to it via VNC and install another OS.
Josep
Thank you for your fast response.
That worked.
