I tried following the advice in other posts for lengthening the bootloader delay so that I can intercept it with keyboard space key presses. I can lengthen the delay (using the Config Block Editor tool), but during boot up the keyboard is not active at all and so it does not see my key presses.
I have a virgin Colibri T30 board which came with Windows CE and I have it plugged into a Colibri Evaluation Board.
I am following the instructions for flashing Linux and Step 17 is where it says to enter the space key on powerup to enter the bootloader.
How do I enable the keyboard during this countdown so that it will recognize my key strokes?! I tested they keyboard - it works fine. It just has no power during the bootloader delay.
The link for the steps I am following is: Update the Linux Image - Colibri Evaluation Board
