Cannot build image for the Yocto apalis-imx8 machine with kirkstone-6.x.y due to missing DTB file
I tried to build a Yocto image for the apalis-imx8 machine. However, the Toradex kernel does not build due to a missing DTB file:
| make[1]: *** No rule to make target 'arch/arm64/boot/dts/freescale/imx8qm-apalis-eval.dtb'.  Stop.
| make: *** [/home/test/oe-apalis/build/tmp/work-shared/apalis-imx8/kernel-source/Makefile:1432: freescale/imx8qm-apalis-eval.dtb] Error 2
meta-toradex-bsp-common is at commit dbc9d3d74c81387cafa292bf06bf7ae91f5c3640 .
meta-toradex-nxp is at commit 45d4fd4ed2b8b31de5e548dcc4acc81178a424ca .
Both layers are on branch kirkstone-6.x.y.
Looking into the kernel source tree, I can only find the following files with “apalis” in their names:
$ find -iname '*apalis*'
./arch/arm/boot/dts/tegra124-apalis.dtsi
./arch/arm/boot/dts/tegra124-apalis-v1.2.dtsi
./arch/arm/boot/dts/tegra30-apalis-eval.dts
./arch/arm/boot/dts/imx6q-apalis-ixora.dts
./arch/arm/boot/dts/imx6qdl-apalis.dtsi
./arch/arm/boot/dts/tegra124-apalis-emc.dtsi
./arch/arm/boot/dts/tegra30-apalis-v1.1.dtsi
./arch/arm/boot/dts/tegra124-apalis-v1.2-eval.dts
./arch/arm/boot/dts/tegra124-apalis-eval.dts
./arch/arm/boot/dts/tegra30-apalis.dtsi
./arch/arm/boot/dts/imx6q-apalis-ixora-v1.1.dts
./arch/arm/boot/dts/tegra30-apalis-v1.1-eval.dts
./arch/arm/boot/dts/imx6q-apalis-eval.dts
imx8qm-apalis-eval.dtb is nowhere to be found.
Any idea what is going on? Commit 08711132d7c2c0e28091f0275f42bff6f85e15db in meta-toradex-nxp states that these devicetree files exist again after the kernel upgrade to 5.15-2.1.x, but they apparently don’t exist.
Hello @crg8000 ,
I have looked in our git repository and for the branch that you mention ( 5.15-2.1.x), I can find the device tree sources
https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm64/boot/dts/freescale?h=toradex_5.15-2.1.x-imx
Have you checked out the correct branch for the kernel sources?
Josep
I use whatever the linux-toradex kernel recipe uses in meta-toradex-nxp. Currently, that recipe points to branch toradex_5.15-2.1.x-imx and commit a8d2c55c6ae71c54878e1394fde1c6aa66786f6b (" arm64: dts: imx8mp-verdin: enable hpd on hdmi-connector") in linux-toradex. Note that you referred to a different branch (toradex_5.4-2.1.x-imx).
Looking that that kernel’s git history, it seems that the recipe needs to be updated, since subsequent commits in the kernel do reintroduce the DTS files correctly.
Noted the error. I have updated the link to the correct branch
I managed to get it to work, but I am unsure if this is OK. I attached the patch here:
linux-toradex-kirkstone-fix.patch (571 Bytes)
Hi @crg8000
Just a quick FYI: BSP 6 was not released yet for Apalis iMX8 nor Colibri iMX8X.
