Can0 goes BUS-OFF after cansend
I seem to have the same problem on an imx7 colibri using flexcan1 (pins 55 and 63). The state goes to BUS-OFF as soon as I try to send the first message.
    # ip -details link show can0
    4: can0:  mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
        link/can  promiscuity 0 minmtu 0 maxmtu 0
        can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
              bitrate 250000 sample-point 0.875
              tq 250 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
              flexcan: tseg1 4..16 tseg2 2..8 sjw 1..4 brp 1..256 brp-inc 1
              clock 24000000numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    # cansend can0 123#deadbeef
    4: can0:  mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
        can state BUS-OFF (berr-counter tx 0 rx 0) restart-ms 0
    # dmesg | fgrep -i can
    [   12.015535] CAN device driver interface
    [   12.045204] flexcan 30a00000.can: 30a00000.can supply xceiver not found, using dummy regulator
    [   80.563886] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
    [  116.604819] can: controller area network core (rev 20170425 abi 9)
    [  116.616042] can: raw protocol (rev 20170425)
    [  116.618702] flexcan 30a00000.can can0: bus-off
I’m running this from a docker image with these numbers:
    # cat /etc/issue
    Debian GNU/Linux 10 \n \l
    # cat /etc/os-release
    PRETTY_NAME="Debian GNU/Linux 10 (buster)"
    NAME="Debian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
And the Torizoncore version:
    ~$ cat /etc/os-release
    ID=torizon-upstream
    NAME="Torizoncore Upstream"
    VERSION="5.1.0+build.1 (dunfell)"
    VERSION_ID=5.1.0-build.1
    PRETTY_NAME="Torizoncore Upstream 5.1.0+build.1 (dunfell)"
    BUILD_ID="1"
    ANSI_COLOR="1;34"
    ~$ cat /etc/issue
    Torizoncore Upstream 5.1.0+build.1 \n \l
Hope this is relevant.
Has any solution to this issue been found?
