Can the pins on the OSM iMX93 be configured for 3.3V?
The user manual shows that pins only work on 1.8V
If yes, how?
If not, why not? Can this update/fix be requested somehow?
P.S.: I’m not looking for a generic, random reply from a bot. I already know how to use a garbage generator. I’m on a human forum because I’m looking for responses from human designers.
I don’t have specific information in the available sources about voltage configuration options for the OSM iMX93 pins or whether they can be configured for 3.3V operation.
To get accurate information about:
  • Pin voltage configuration capabilities
  • Whether 3.3V operation is supported
  • Hardware limitations of the OSM iMX93 regarding I/O voltage levels
  • Potential workarounds or future updates
I recommend:
  1. Checking the OSM iMX93 Datasheet - The OSM iMX93 Datasheet(1) should contain detailed electrical specifications including supported I/O voltage levels and any configuration options.
  2. Reviewing the NXP i.MX 93 Reference Manual - Since the OSM iMX93 is based on the NXP i.MX 93 SoC(1), the NXP documentation will detail the SoC’s voltage domain capabilities and any voltage selection mechanisms.
  3. Contacting Technical Support - For specific voltage configuration questions and feature requests, please reach out through Toradex Technical Support Channels(1).
If 1.8V-only operation is a hardware limitation of the i.MX 93 SoC itself, voltage level shifters on your carrier board would be the typical solution for interfacing with 3.3V peripherals.
No, this reply was not useful. It is just random garbage. I need a response from real human designers.
I understand your frustration. Unfortunately, I don’t have access to the specific electrical specifications for the OSM iMX93’s I/O voltage configuration in my current information sources.
A human engineer from Toradex will need to provide you with:
  1. Confirmation of supported I/O voltage levels (1.8V only vs. configurable)
  2. Hardware limitations of the NXP i.MX 93 SoC used on the OSM iMX93
  3. Whether voltage selection is possible through software or hardware configuration
  4. Recommended solutions if 3.3V operation is not natively supported
The Toradex support team monitors this forum and should respond with the technical details you need directly from the engineering team.
Yes, on most interfaces except special cases like SDIO or RGMII
By design and according OSM specification.
what “Why Not”?
Could you please clarify what exactly you believe should be fixed or updated?
Which specific pins do you need to be at 3.3 V? Please check the OSM specification first to confirm whether this complies with the standard.
Human designers also dislike garbage, no matter whether it was generated by a human or by AI.
This response started to look like human garbage.
Start by looking at the first line of the response.
I stated that the user manual shows the pins only work at 1.8 V. The answer was, “Yes.” (Yes, of course. I saw the user manual. That was a statement, not a question.)
Then, in the same line, it says, “except for special cases like SDIO and RGMII.” Are you saying those interfaces work at 3.3 V and not on 1.8 V. Where does the user manual say that? This seems exactly the opposite what is expected. Everything on 1.8V while the SDIO and RGMII work on 3.3 V.
By design.
Are you saying that by design the IOs work on 1.8 V (and not 3.3 V), correct?
Ok, so OSM specifies the thing has to work on 1.8 V.
The IO voltage level could be set by the user as any other chip. But if this is in the OSM standard then this is answered already.
Exactly, so why do you throw AI garbarge on people that need help? If someone needs random garbarge they can as AI directly.
Please read the module datasheet most of your question are explained there
In any case, not all i.MX93 SoC I/Os can be configured for 3.3 V operation.
I don’t use SDIO this explains why I didn’t see it. But thank you.
It seems that, unfortunately, OSM is not the right package for my application.
