Hi All
I have followed Installing the Operating System - Iris Carrier Board this link for installation new OS using Toradex easy installer.
I done all the process in smooth way.[upload|qYMyoRsUzuvVRDV+OcY2KJhvog0=]
Please help me to sort this problem.
Best Regards.
Hanmant.
Hi @hanmant9096
Could you provide the software version of your module?
Which display and interface are you using?
Did you already have a look here?
@jaski.tx .
I have flash the colibri-imx7-emmc_lxde-image-tezi_2.8b6.184-20190401 into SOM using Toradex Installer. After that flashing done and Power-off and Power-on then I didnot see any on desktop/monitor it supposed to see Toradex Desktop; but i able to see through UART.
I have not used any display.
My setup is like
1)Colibri-iMX7-emmc SOM
2)Iris Carrier Board.
3)I have connected Iris Board(X13) UART to my Host Computer
4)I have connected my another Desktop/Monitor through VGA cableto Iris board (DVI to VGA adapter)
so what I have to do for it.
What is model of your display?
@jaski.tx
Im not using any display now.
Hi, Sorry I mean this.
What is the model of your Monitor?
@jaski.tx
im using AOC LCD Monitor 15" ich (1366x768).
Please tell me what i need do.
Hi @hanmant9096
Did you set up the correct frame-buffer settings as explained here?
@jaski.tx
I have changed Monitor which is resolution High as compared past one.
so i can see normal display now.
Can you see the desktop now?
Yes ! Now i can see.
Thank You
Hanmant
Perfect. Thanks for the feedback.
