Technical Support queries
Hi all,
Can I use the tamper detection function in Apalis iMX8QM?
The MCU has two In/Out pins, but I don’t think that is on the connector pins of the Apalis computer-on-module.
Does this mean that the external tamper function cannot be used in Apalis?
Sorry if I have missed something.
Yukio Oyama
yes it looks like according to our Pinout the tamper pins are not routed to the edge connector.
I will check with R&D if there are other ways to get Tamper protection.
Best Regard,
Matthias
Hello so no tamper pin.
The limitation of pin on the MXM connector did not allow for having the tamper pins as well on the Apalsi imx 8
Matthias Gohlke
