What are some Python modules are supported by VF61. Flask, twisted , pyqt?
Assuming Linux, the python flask and twisted modules can be installed with opkg as these are available in Angstrom as well as our Toradex feeds.
opkg update
opkg install python-stringold
opkg install python-netserver
opkg install python-twisted
Flask has dependencies on quite a few modules one of them being werkzeug. While werkzeug can be installed with opkg that particular version installable with opkg is old and seems to give a different problem.
Install flask with opkg
opkg install python-flask
and then install pip with
opkg install python-pip
Using pip now install a few other python modules which flask requires.
pip install werkzeug
pip install jinja2
pip install itsdangerous
twisted and flask should now be usable.
# python
Python 2.7.9 (default, Mar 15 2016, 15:40:05)
[GCC 5.2.1 20151005] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import twisted
>>> import flask
python-pyqt is not available in the feeds and would require building through OpenEmbedded. Please refer the following article for OpenEmbedded setup.
I installed python-twisted
but simple “import twisted” in program is saying no module twisted.
Which image version are you using? The python twisted module has dependencies on python-stringold and python-netserver. Doing the following
and then
root@colibri-vf:~# python
Python 2.7.9 (default, Sep 30 2015, 12:09:35)
[GCC 4.9.3 20150311 (prerelease)] on linux2
>>> import twisted
I tested this on Colibri VF61 with the latest image.
I am using GCC 4.8.3. its not working on GCC 4.8.3. My python version is 2.7.3.
Which image version are you using? What is the result of
cat /etc/version
on the module? What all commands did you execute with opkg?
Angstrom v2014.06
Please try with a recent up to date v2.5 Beta2 or v2.5 Beta3 image.
@koustubhavachat, did installing the packages mentioned above resolve your problem? If not, which Toradex BSP/image version are you using? Check cat /etc/issue
to get the image release date.
I am using Colibri_VF_LinuxImageV2.3_20141031. I will change it to 2.5_20151216 given in Single Board Computers (SBCs), Computer on Modules, System on Modules
