We are planning to use a carrier board that can fit an Apalis iMX6 as well as a Verdin Plus module (through the use of an adapter board).
For some functionality, we want to use some pins (pin 46, 97, 101) of the Apalis interface that are declared as “not connected” in the Apalis datasheet. (These pins will be routed to certain pins on the Verdin interface on the adapter board.)
Is it safe to use these pins, i.e., are they truly not connected, or could we run into problems in doing this?
