Can I connect a weigand reader on vf61 without using any converter?
We are trying to launch a two reader access controller. For this we are willing to use VF61. So we need to use wiegand reader as card reader.
Now my question is can I connect a weigand reader on vf61 without using any converter?
If yes, how to connect that reader? Also how to retrieve the card number from that wiegand reader?
Dear @Meeta
Wiegand uses a proprietary protocol, which is not supported in our software.
I don’t know the details of this protocol. Maybe it is possible to write your own driver and access the data using a bit-banging approach (generate the signals manually by toggling GPIOs in the correct way).
Regards, Andy
