Can I add POE to the Colibri iMX6ULL?
I am designing a board (carrier board) that connects to the Colibri iMX6ULL.
I want to add POE functionality (PSE) to that board.
Is it possible by adding a POE IC?
Also, is there a circuit that can be used as a reference?
The maximum power consumption if Colibri iMX6ULL module itslef is around 1Watt. So any type of PoE specification can be used to power it. Unfortunately we do not have a reference design for PoE. However you can integrate a reference design provided by IC manufacturers. For example - https://www.digikey.com/reference-designs/en/power-management/poe-power-over-ethernet
Thanks for the answer.
However, I think your answer is about PD (Powered Device), isn’t it?
The information I want to know is about PSE (Power Sourcing Equipment).
Can I combine the Ethernet PHY (KSZ8041NL) of the Colibri iMX6ULL with the PSE IC (e.g. TPS23861) of the carrier board to supply power to other devices?
The KSZ8041NL signals TX +, TX-, RX+ and RX1 are routed out directly to X1 connector. No other Ethernet related signals are available except LAN_LED0/LAN_LED1. You can try to find PSE IC which can be interfaced directly with KSZ8041NL, but we don’t have any ready to use solution for this case.
