in my application I use CAN lib (CE Lib 2.0b4174-20171120 preliminary release). If I first send a frame with 8 data bytes and then with 1 data byte, everything is fine. But after that I send again a frame with 8 data bytes and get the following error message from output:
CAN Error: Receive buffer is small
Unknown: DEBUGCHK failed in file .\src\can_fastFlex.cpp at line 493
Application.exe has triggered a breakpoint.
I modified the CANDemo example so that it works similar to my application. Also used the same libs. And there it works. Only get the error:
CANClass::CANInterruptHandler: CAN_TWRN_INT_BIT intr Occor
CAN: overrun.
CAN: queue overrun.
if I send to many frames.
What does this error mean? Can I somehow avoid the crash?
