Building the full Qt toolchain using Bitbake Fails
Hello Sir/Madam,
I want to build the HMI using Qt for Apalis Evaluation Test Board V1.1A , SoM: Apalis iMX6 Quad 2GB. I am following the link as mentioned below:
  1. Getting Started with Qt
  2. Qt Creator to cross compile - Embedded Linux
Build the SDK for development
[build] $ bitbake -k meta-toolchain-qt5
During the building process I get an error each time and even the Ubuntu is completely hanged and need to restart always
ERROR: Task (/home/user/oe-core/build/…/layers/meta-qt5/recipes-qt/qt5/qtquickcontrols2_git.bb:do_compile) failed with exit code '1’
I even followed the “Failing Build” Section but of no help.
Request your help for the same
Thanks and Regards,
Amar V
Hi @amar
Could you provide the version of the openembedded branch your are trying to compile?
Could you provide the error log?
What is the hardware and software ( uname -a )of your build host?
Dear @jaski.tx ,
Thank you for the feedback The details for your perusal is mentioned below
uname -a
Linux BLTSP01121B 4.15.0-55-generic #60~16.04.2-Ubuntu SMP Thu Jul 4 09:03:09 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
The snapshot of the error log is mentioned below
**5.11.3+gitAUTOINC+beaeeb9988-r0/git/Source/WTF/wtf/HashTraits.h:226:8: note: 'struct WTF::KeyValuePair >' declared here
|  struct KeyValuePair {
| ninja: build stopped: subcommand failed.
| ERROR: Function failed: do_compile (log file is located at /home/user/oe-core/build/tmp/work/armv7at2hf-neon-tdx-linux-gnueabi/qtwebkit/5.11.3+gitAUTOINC+beaeeb9988-r0/temp/log.do_compile.29832)
ERROR: Task (/home/user/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qtwebkit_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5286 tasks of which 5267 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory**
link text
Request your assistance for the same
Thanks and Regards, Amar V
Hi @amar
Could you share your local.conf?
Dear @jaski.tx ,
I am not aware on how to check the open embedded branch version. Request your help on the same
The local.config file contents is mentioned below for your perusal
Local.conf
Amar V
Which branch did you check out?
Dear @jaski.tx ,
I am beginner to LINUX and I am following the links mentioned.
I am not sure on check out of the branch I have performed until now
Thanking you in anticipation
I am successful with this command :
bitbake -k console-tdx-image
And also have built the SDK
bitbake console-tdx-image -c populate_sdk
