Hello support!
I have installed VS2015, Platform builder, downloaded BSP and Work space for WinCE8 from your website.
I have copied BSP files to C:\WINCE800\platform
After opening work space I tried to build image. I have not changed any settings and used default whatever was in Workspace.
Image was created successfully and I received at the end file called NK.bin which is uncompressed image for Colibri iMX6 board with WinCE8 inside.
After loading up the image to Colibri iMX6 board nothing worked. It does not look like board boots up.
Board does not boot to WinCE shell.
Can you please provide details about proper image compilation steps using your Workspace and BSP for iMX6 Colibri board ?
We are happy to use your image for iMX6 but unfortunately your image missing WiFi support for WiFi dongle which we got form you and now we have to rebuild this image in order to get WiFi running.
I am only getting standard:
Toradex Bootloader 1.0 BETA 6 for Colibri Built Jan 12 2016
Initializing L2 Cache.
Board: Colibri iMX6 DualLite 512MB
CPU is running at 984000MHz.
eMMC boot partition not in use.
Loading EBoot configuration…
16 sectors of configuration data loaded from user.
Press [SPACE] to enter Bootloader Menu
Initiating image launch in 2 seconds. 1 seconds. 0 seconds.
System ready!
Preparing for download…
Loading uncompressed image…
Loading 56231072 bytes to RAM
Done.
Nothing further works.
What are the specific settings for compiling of the uncompressed image ?
Thank you,
Vlad
