Hello everyone.
I’m trying to build a reference image with Yocto Project for iMX6ULL using the BSP 6. I cloned the repo via the commando below.
$ repo init -u git://git.toradex.com/toradex-manifest.git -b kirkstone-6.x.y -m tdxref/default.xml
$ repo sync
It was able to building the tdx-reference-minimal-image. However, when I tried to build the tdx-reference-multimedia-image the console is closing when is highest the 85% without error message. I set the local.conf
as:
MACHINE ?= "colibri-imx6ull"
ACCEPT_FSL_EULA = "1"
And run the command
bitbake tdx-reference-multimedia-image
I tried again, this time using the command
bitbake -k tdx-reference-multimedia-image
And I got an enormous message with the error message. In a total, the process is finalized with 6 errors.
Sstate summary: Wanted 602 Local 349 Mirrors 0 Missed 253 Current 2699 (57% match, 92% complete)
NOTE: Executing Tasks
ERROR: gtk+3-3.24.34-r0 do_compile: oe_runmake failed
ERROR: gtk+3-3.24.34-r0 do_compile: ExecutionError('/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/gtk+3/3.24.34-r0/temp/run.do_compile.163675', 1, None, None)
ERROR: Logfile of failure stored in: /home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/gtk+3/3.24.34-r0/temp/log.do_compile.163675
Log data follows:
| DEBUG: Executing python function autotools_aclocals
i/gtk+3/3.24.34-r0/recipe-sysroot/usr/lib/Scrt1.o: in function `_start':
| /usr/src/debug/glibc/2.35-r0/git/csu/../sysdeps/arm/start.S:118: undefined reference to `main'
| collect2: error: ld returned 1 exit status
| make[4]: *** [Makefile:547: exampleapp] Error 1
| make[4]: Leaving directory '/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/gtk+3/3.24.34-r0/build/examples/application8'
| make[3]: *** [Makefile:502: all] Error 2
| make[3]: Leaving directory '/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/gtk+3/3.24.34-r0/build/examples/application8'
| make[2]: *** [Makefile:720: all-recursive] Error 1
| make[2]: Leaving directory '/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/gtk+3/3.24.34-r0/build/examples'
| make[1]: *** [Makefile:743: all-recursive] Error 1
| make[1]: Leaving directory '/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/gtk+3/3.24.34-r0/build'
| make: *** [Makefile:616: all] Error 2
| ERROR: oe_runmake failed
ERROR: Task (/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/../layers/openembedded-core/meta/recipes-gnome/gtk+/gtk+3_3.24.34.bb:do_compile) failed with exit code '1'
ERROR: qt3d-native-5.15.7+gitAUTOINC+bf79d391c0-r0 do_compile: oe_runmake failed
ERROR: qt3d-native-5.15.7+gitAUTOINC+bf79d391c0-r0 do_compile: ExecutionError('/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/x86_64-linux/qt3d-native/5.15.7+gitAUTOINC+bf79d391c0-r0/temp/run.do_compile.163940', 1, None, None)
ERROR: Logfile of failure stored in: /home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/x86_64-linux/qt3d-native/5.15.7+gitAUTOINC+bf79d391c0-r0/temp/log.do_compile.163940
Log data follows:
| DEBUG: Executing shell function do_compile
| make[2]: *** [Makefile:1005: ../../bin/qgltf] Error 1
| make[2]: Leaving directory '/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/x86_64-linux/qt3d-native/5.15.7+gitAUTOINC+bf79d391c0-r0/build/tools/qgltf'
| make[1]: *** [Makefile:47: sub-qgltf-make_first] Error 2
| make[1]: Leaving directory '/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/x86_64-linux/qt3d-native/5.15.7+gitAUTOINC+bf79d391c0-r0/build/tools'
| make: *** [Makefile:47: sub-tools-make_first] Error 2
ERROR: Task (virtual:native:/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qt3d_git.bb:do_compile) failed with exit code '1'
ERROR: qtbase-5.15.7+gitAUTOINC+358aebba72-r0 do_compile: oe_runmake failed
ERROR: qtbase-5.15.7+gitAUTOINC+358aebba72-r0 do_compile: ExecutionError('/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/qtbase/5.15.7+gitAUTOINC+358aebba72-r0/temp/run.do_compile.163600', 1, None, None)
ERROR: Logfile of failure stored in: /home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/tmp/work/armv7at2hf-neon-imx-tdx-linux-gnueabi/qtbase/5.15.7+gitAUTOINC+358aebba72-r0/temp/log.do_compile.163600
| make: *** [Makefile:51: sub-src-make_first] Error 2
ERROR: Task (/home/charlesdias/Project/DreaMau/Industrial_V2/Linux-Image/yocto-imx6ull-bsp6/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qtbase_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 7621 tasks of which 7545 didn't need to be rerun and 3 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 5 seconds
Summary: 3 tasks failed:
Summary: There was 1 WARNING message.
Summary: There were 6 ERROR messages, returning a non-zero exit code.
Thanks for your help!
