Build image with modified LCD info in panel-simple.c file
I see in panel-simple.c there are LCD definitions which i can then use in my panel definition in my device tree such as
panel_dpi: panel-dpi {
compatible = “edt,et057090dhu”;
I have found the panel-simple.c file in my build folder
If i modify this file, how do i get it built into my image ?
The parallel RGB LCD display parameters for Colibri iMX6 modules are configured via the Device Tree. For more information, please refer to this article
I believe i need bgr666 which does not exist at the moment as an option in panel-simple.c , therefore i wanted to create one and get the panel-simple into my build so i can select the new display type i will create.
I have modified this file BUT i cant seem to get it ‘added’ to my kernel or image build.
Hi @adrian ,
which version of the image are you trying to build?
Kevin
