BSP ID incorrect on Vybrid WEC2013 image
This is just a heads up: the BSP ID in the latest Vybrid WEC2013 image is incorrect.
Using Sys_GetConfigInt to read out the BspVersion parameter, the value is 0x0105ff03.
According to the documentation, this corresponds to V1.5 Colibri IMX6; it should be V1.5 Colibri Vybrid.
Dear @Monomix
This is a wrong documentation.
I assume you found this information in the librariy’s help file (*.chm), or in SysInfo.h which is used to generate the help file? If you found it anywhere else, please let me know so we can fix it.
The correct documentation should be:
BspId (bits [3:0], 0=Unknown, 1=PXA, 2=Tegra, 3=Vybrid, 4=Imx6, 5=Imx7)
  Example: 0x02000102 = 0x02_00_01_0_2 = V2.0b1 (Colibri Tegra)
  Example: 0x0200FF12 = 0x02_00_FF_1_2 = V2.0   (Apalis Tegra)
The implementation in the SysInfo_Demo application is correct. We will fix the documentation in the next library release V2.3. Thank you for pointing out the problem.
Regards, Andy
Hi Andy,
Yup, I was going on the library help file. Thanks for the super-fast response!
Cheers,
Garry
