Hi there,
i am using a Apalis IMX8QM 4GB WB IT and Torizon Core 5.3 for a small Docker application.
I was trying to reduce boot time when i stumbled over the udisks2.service which takes up to about 25 seconds.
systemd-analyze blame | head
29.102s plymouth-quit-wait.service
25.523s udisks2.service
10.429s NetworkManager-wait-online.service
3.913s docker.service
1.316s dev-disk-by\x2dlabel-otaroot.device
1.303s plymouth-quit.service
1.008s systemd-logind.service
832ms systemd-networkd.service
780ms systemd-resolved.service
624ms systemd-journald.service
A closer look revealed a timeout on polkit.
systemctl -l status udisks2
● udisks2.service - Disk Manager
Loaded: loaded (/usr/lib/systemd/system/udisks2.service; disabled; vendor preset: disabled)
Active: active (running) since Thu 1970-01-01 00:00:32 UTC; 3min 20s ago
Docs: man:udisks(8)
Main PID: 697 (udisksd)
Tasks: 5 (limit: 3206)
Memory: 13.0M
CGroup: /system.slice/udisks2.service
└─697 /usr/libexec/udisks2/udisksd
Jan 01 00:00:06 apalis-imx8-06875081 systemd[1]: Starting Disk Manager…
Jan 01 00:00:06 apalis-imx8-06875081 udisksd[697]: udisks daemon version 2.9.0 starting
Jan 01 00:00:31 apalis-imx8-06875081 udisksd[697]: Error initializing polkit authority: Error initializing authority: Error calling StartServiceByName for org.freedesktop.PolicyKit1: Timeout was reached (g-io-error-quark, 24)
Jan 01 00:00:32 apalis-imx8-06875081 systemd[1]: Started Disk Manager.
Jan 01 00:00:32 apalis-imx8-06875081 udisksd[697]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Is there a easy way to get rid of this error? Or at least to set the Timeout to a lower time?
Thanks for the help.
