I’ve copied Tezi 1.8 (and 2.0 as well) from web on SD card and I wanted to boot into it through U-Boot. Not from recovery mode. But without success:
Colibri iMX7 # run distro_bootcmd
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
464 bytes read in 15 ms (29.3 KiB/s)
## Executing script at 87000000
21374744 bytes read in 981 ms (20.8 MiB/s)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
SCRIPT FAILED: continuing...
I think the problem is in the zImage vs uImage case, because when run the same command from 2016.11 U-Boot I can boot into Tezi not only from SD but from TFTP as well.
Thank you technically it solved the issue Wrong Image Format for bootm command. But have you tried booting into Tezi? Because all I get after recompiling is [ 4.246802] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b You can see more in complete boot log
Did you try to boot Toradex Easy Installer version 2.0b5? I tested at my place and it works.
You won’t able to run Toradex Easy Installer 1.8 since some configuration of U-Boot 2019.07 is not compatible with Kernel 4.1 used in Toradex Easy Installer 1.8.
