After following the instructions here Build Apalis iMX8/Colibri iMX8X OpenEmbedded/Yocto Project Bring-up Image to update uboot. The system now infinitely resets as in the screenshot. It also will no longer boot into recovery, with the jumper in place it no longer resets continuously but recovery mode does not come up through the serial connection.
HI @matthewh628
Welcome to the Toradex Community!
Could you provide the software version of your module?
Which carrier Board are you using?
Which Version of Toradex Easy Installer are you using?
Hi @jaski.tx
Software version: I’m not sure exactly what you’re asking for here, we make our own custom image which we have running and working on the same model of iMX8 and the same carrier board attempting to be used with this one. From a conversation my company has had in the past with Toradex it’s my understanding that the uboot on this device was never updated for the timings of this module.
Carrier board: Ixora V1.1B
Easy Installer version: Did not use Easy Installer, used the directions here We used the same instructions for the other iMX8 using the same image and it worked just fine.
Hi
cat /etc/issue
or 'uname -a`
Ok, so you did not update to the latest Bsp 3.0b3.
This tooling was for a early Bring-up phase? Now we recommend using Toradex Easy Installer.
Could you use Toradex Easy installer to flash Bsp 3.0b3 on your module and provide an error log?
I tried using Easy installer and the script ran successfully
on my computer however over serial the iMX8 is outputting this error.Could you share a complete log with your commands and output in text format instead of a printscreen?
This is from my local machine:
root@matthew:/home/matthew/Downloads/Apalis-iMX8_ToradexEasyInstaller_2.0b4-20191231# ./recovery-linux.sh
Downloading Toradex Easy Installer...
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.3.102-0-gb078bd0
Success 1 Failure 0
Successfully downloaded Toradex Easy Installer. ] FB: done
This is from the iMX8:
U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39 (Dec 31 2019 - 15:53:00 +0000)
CPU: Freescale i.MX8QM revB A53 at 1200 MHz at 21C
DRAM: 4 GiB
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1B, Serial# 06452621
BuildInfo:
- SCFW 494c97f3, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF a-20190
- U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39
switch to partitions #0, OK
Detect USB boot. Will enter fastboot mode!
Net: eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: fastboot 0
Starting download of 2225 bytes
downloading of 2225 bytes finished
Starting download of 102464 bytes
downloading of 102464 bytes finished
Starting download of 37130512 bytes
downloading of 37130512 bytes finished
## Executing script at 82e00000
Loading hdp firmware from 0x0000000082fe0000 offset 0x0000000000002000
Loading hdp firmware Complete
## Loading kernel from FIT Image at 83000000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.14.159-2.0.4+gfff496c2a1bd
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x830000f4
Data Size: 6676173 Bytes = 6.4 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x80280000
Entry Point: 0x80280000
Hash algo: md5
Hash value: a31874602b85bbb1d182034cbecd204f
Verifying Hash Integrity ... md5 error!
Bad hash value for 'hash@1' hash node in 'kernel@1' image node
Bad Data Hash
ERROR: can't get kernel image!
Hi
How did you extract the Toradex Easy Installer Image?
Do you see this error on the other iMX8 module too?
I unzipeed it with the linux command unzip.
I’m testing on the other iMX8 now, but the iMX6 Easy Installer worked fine on one of our iMX6 modules
EDIT: It does work on our other iMX8 module
HI @matthewh628
Thanks for your feedback.
If one iMX8 module is not working, then it might have some hardware issues. We are sorry, that you have this experience with our hardware.
You could file up a RMA and mention this community thread as comment.
