I was wondering if there was a way to change the default boot interface from SD Card to FlexSPI. Nominally this would be done by changing the SCU_BOOT_MODE pins. It appears the SCU_BOOT_MODE pins are not routed through the X1 connector. Are there plans to add these lines to the X1 connector or is there an alternate way to have the ROM code select the FlexSPI as the boot interface? Thanks
-Carlos
