Hi Germano.
I tested the new bootloader and actually the boot time has drastically reduced.
Can I then upload it to all the som I have in production?
Thank you.
Sergio M.
Hi Germano.
Thank you.
Sergio M.
Hi @smasin ,
Generally i would not recommend to use prerelease versions of our software… but if you tested it well enough that you’re confident it will work properly for all your usecases you can do so… The main purpose i sent it to you was to increase the test base so you might find an issue that i did not see… as i said i will do a proper release end of this month… It will also improve the \FlashDisk Read/Write performance in the Image once it’s done.
Hi Germano.
Ok, for now I use it internally as a test, I await the official release.
Can you give me the link where I will find the new official version.
Thanks.
Sergio M.
Hi Germano.
Where can I download the updated version of eboot.spl for cpu Colibri iMX6S 256MB IT ?
Sergio M.
