I have an iMX6ULL 512MB WB IT, where I would like to use bluethoot.
I would like to use it in the way that is discoverable, that is, first enabled the BT in the Colibri, then with a device like a smartphone doing research should appear on the phone display also the BT of the colibri and then connect.
It does not appear.
I executed these commands:
connmanctl enable bluetooth
systemctl start bluetooth
hciconfig hci0 up
hciconfig hci0 reset
hciconfig piscan
On the other hand, trying to scan on, the colibri BT finds the devices (for example the telephone).
Since the final hardware will have no display I need this function so that you can see the BT of the colibri from a smartphone to connect and not vice versa
in attachment you can see the dmesg output log.
The smartphone we are using is a Samsung J6, but we have also tried with different iPhones model, from iPhone 5s to iPhone X. link textWhat is the problem?
Thank you
In my wifi/BT module the hare two connectors:
MAIN and AUX, i the kit Toradexlink text provided there is only one antenna.
Where I have to connect it? To the AUX or to the MAIN?
If I want to use also WIFI do I need another additional antenna?
In general, it is recommended to use two antennas in order to have the best performance. However if you really wants to use, then check this site and do the run time Configuration.
