Ok thanks … If I launch the blinking led application with remote proc once the kernel has started , no problem, it works …
But if I try with RPMSG String Echo example, it’s the opposite … I can run it from the uboot and start the kernel after without problem, but it fails if I run it with remote proc ( kernel panic )
Could you check on your side, please ?
