Hello!
I have been following these guides:
Here are the commands I have run:
mkdir ~/bin
export PATH=~/bin:$PATH
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
cd ~/bin
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImage3.0 -m default.xml
repo sync
. export
sudo nano conf/local.conf
← uncommented MACHINE for apalis iMX6
cd ..
mkdir stuff
git clone -b toradex_4.14-2.3.x-imx git://git.toradex.com/linux-toradex.git
cd linux-toradex
sudo patch -p1 < ~/patch/seventhTry.path
← applying my patch, only edits /drivers/i2c/busses/i2c-imx.c and /drivers/i2c/busses/Kconfig
cd ../build
bitbake linux-toradex
← screenshot of build configuration is as follows
When I run ls /deply/images/apalis-imx6
, there is not a tar.bz2 file. This is what is inside that directory:
Is there another place I can look for the .tar.bz2 file in order to flash my iMX6? Did I happen to configure it not to make the .tar.bz2 file?
Thanks for helping out!
