I tried to create the LXQT-image with bitbake. I pulled the LinuxImage3.0 revision, configured the script to Colibri iMX6 target. Almost everything built successfully, but the qt3d always failed.
I tried the bitbake -c cleansstate qt3s, then rebuild, but the same error occured:
make[1]: Leaving directory '/home/barracuda/oe-core/build/tmp/work/armv7at2hf-neon-mx6qdl-tdx-linux-gnueabi/qt3d/5.11.3+gitAUTOINC+cd3e621ccf-r0/build/tests'
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/barracuda/oe-core/build/tmp/work/armv7at2hf-neon-mx6qdl-tdx-linux-gnueabi/qt3d/5.11.3+gitAUTOINC+cd3e621ccf-r0/temp/log.do_compile.4424)
ERROR: Task (/home/barracuda/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qt3d_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 9303 tasks of which 9295 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
What am I missing, or is it even possible to build the LXQT-image?
A tried to raise the swap memory from 2GB to 2.5GB, but I think the 2GB should be enough too.
My build computer is Ubuntu 18.04, core i5-4460 cpu with 8GB ram. I successfully built the latest boot2qt image, so I think the computer is enought for this task. But I wanted to try to build the LXQT version because of the windowing system.
I modified the layers.conf the following:
uncommented the colibriu-imx6 target.
and added theese lines:
Thanks for your Input. We are building lxqt images every night, so the build should work.
Being said that, could you share the error log ( /home/barracuda/oe-core/build/tmp/work/armv7at2hf-neon-mx6qdl-tdx-linux-gnueabi/qt3d/5.11.3+gitAUTOINC+cd3e621ccf-r0/temp/log.do_compile.4424 )?
