Bitbake -k meta-toolchain-qt5 fails
Ubuntu 14.04 installed in VM. Following steps per OpenEmbedded (core) and Setup Qt Creator for Cross Compile, the build fails. Here are the steps I’m following:
# Install needed shell tools
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib build-essential chrpath libsdl1.2-dev xterm
# Install build tools
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install g++-4.8-multilib
sudo apt-get install chrpath curl gawk g++-multilib gcc-multilib lib32z1-dev libcrypto++9:i386 libcrypto++-dev:i386 liblzo2-dev:i386 libsdl1.2-dev libstdc++-4.8-dev:i386 libusb-1.0-0:i386 libusb-1.0-0-dev:i386 texinfo uuid-dev:i386
cd /usr/lib; sudo ln -s libcrypto++.so.9.0.0 libcryptopp.so.6
# Install repo to help with git repo management
sudo curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > repo
mv repo /usr/local/bin/repo
chmod a+x /usr/local/bin/repo
# Retrieve BSP source
mkdir oe-core
cd oe-core
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.6
repo sync
# Setup build environment (do this for any new shell to be used for building oe-core)
. export
# Adapt build/conf/local.conf to your needs
BB_NUMBER_THREADS ?= "6"
PARALLEL_MAKE ?= "-j 6"
MACHINE ?= "colibri-imx7"
# Accept NXP stuff/meta-fsl-arm/EULA for iMX6 (possibly iMX7)
ACCEPT_FSL_EULA = "1"
# Build image containing qt5. Execute this from oe-core/build directory, with . export environment active
bitbake -k meta-toolchain-qt5
Errors follow:
| linking ../../lib/libQt5WaylandClient.so.5.5.1
| /home/mnelson/oe-core/build/out-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-ld.gold: error: cannot find -lqtfreetype
| /home/mnelson/oe-core/build/out-glibc/work/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/qtbase/5.5.1+gitAUTOINC+5afc431323-r0/git/src/platformsupport/fontdatabases/basic/qbasicfontdatabase.cpp:204: error: undefined reference to 'FT_New_Memory_Face'
| /home/mnelson/oe-core/build/out-glibc/work/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/qtbase/5.5.1+gitAUTOINC+5afc431323-r0/git/src/platformsupport/fontdatabases/basic/qbasicfontdatabase.cpp:236: error: undefined reference to 'FT_Get_Sfnt_Table'
and, several of these types of warnings…
WARNING: QA Issue: qttools: /qttools-dbg/usr/src/debug/qttools/5.5.1+gitAUTOINC+0240288756-r0/git/src/qtpaths/qtpaths.cpp is owned by uid 1000, which is the same as the user running bitbake. This may be due to host contamination [host-user-contaminated]
Thanks for any help you can give.
Hi
Please check this community thread for a fix.
The host-user-contaminated warnings are unrelated. We submitted a patch upstream addressing them.
https://bugzilla.yoctoproject.org/show_bug.cgi?id=8939
You could add the following to local.conf to no longer have them reported:
WARN_QA_remove = “host-user-contaminated”
Max
