My goal is to load python3 and pip on the module Colibri iMX6 Solo 256MB.
Toradex suggests, that you have to make your own image.
I followed the steps described on the link: OpenEmbedded (core) - Toradex System/Computer on Modules.
I work with Ubunu 20.04.2 LTS.
I choose the 5.0.0 BSP version.
In “local.conf” I set:
MACHINE ?= “colibri-imx6”
and add:
IMAGE_INSTALL_append = “python3”
IMAGE_INSTALL_append = " python3-pyserial"
IMAGE_INSTALL_append = " python3-pip"
I run bitbake core-image-minimal.
Bitbake successfully created files in /deploy/images/coliri-imx6.
The problem is that the same created files are not recognizable by Easy Installer.
These files are “link files”. Look attached picture.
I manually delete links and rename tar files as defined in json file:“image-core-image-minimal.json”
After renaming the files, the “Easy installer” correctly recognized the files and also uploaded them and on the end reported that I can reboot the module.
After reboot, the module becomes “Dead”.
Is it the problem in Ubuntu 20.04.2 LTS?
Is the problem 5.0.0 BSP version?
I am also attaching bitbake’s log file:bitbake-cookerdaemon.log (163.2 KB)
Best regards
Raff
