Hi ,
I am trying to build an Image for apalis imx8. I am following steps mentioned in below link
For BSP version 5.0
When i perform bitbake for tdx-reference-multimedia-image
following fetch error is received
ERROR: kernel-module-imx-gpu-viv-6.4.3.p1.4-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH=“/home/rms45/oe-core/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/rms45/oe-core/layers/openembedded-core/scripts:/home/rms45/oe-core/build/tmp/work/apalis_imx8-tdx-linux/kernel-module-imx-gpu-viv/6.4.3.p1.4-r0/recipe-sysroot-native/usr/bin/aarch64-tdx-linux:/home/rms45/oe-core/build/tmp/work/apalis_imx8-tdx-linux/kernel-module-imx-gpu-viv/6.4.3.p1.4-r0/recipe-sysroot/usr/bin/crossscripts:/home/rms45/oe-core/build/tmp/work/apalis_imx8-tdx-linux/kernel-module-imx-gpu-viv/6.4.3.p1.4-r0/recipe-sysroot-native/usr/sbin:/home/rms45/oe-core/build/tmp/work/apalis_imx8-tdx-linux/kernel-module-imx-gpu-viv/6.4.3.p1.4-r0/recipe-sysroot-native/usr/bin:/home/rms45/oe-core/build/tmp/work/apalis_imx8-tdx-linux/kernel-module-imx-gpu-viv/6.4.3.p1.4-r0/recipe-sysroot-native/sbin:/home/rms45/oe-core/build/tmp/work/apalis_imx8-tdx-linux/kernel-module-imx-gpu-viv/6.4.3.p1.4-r0/recipe-sysroot-native/bin:/home/rms45/oe-core/layers/openembedded-core/bitbake/bin:/home/rms45/oe-core/build/tmp/hosttools”; export HOME=“/home/rms45”; LANG=C git -c core.fsyncobjectfiles=0 fetch -f --progress “https://source.codeaurora.org/external/imx/linux-imx.git” refs/:refs/ failed with exit code 128, no output
ERROR: kernel-module-imx-gpu-viv-6.4.3.p1.4-r0 do_fetch: Bitbake Fetcher Error: FetchError(‘Unable to fetch URL from any source.’, ‘git://source.codeaurora.org/external/imx/linux-imx.git;protocol=https;branch=imx_5.4.70_2.3.0;subpath=drivers/mxc/gpu-viv;destsuffix=git/src’)
ERROR: Logfile of failure stored in: /home/rms45/oe-core/build/tmp/work/apalis_imx8-tdx-linux/kernel-module-imx-gpu-viv/6.4.3.p1.4-r0/temp/log.do_fetch.20082
ERROR: Task (/home/rms45/oe-core/build/…/layers/meta-toradex-nxp/backports/recipes-kernel/kernel-modules/kernel-module-imx-gpu-viv_6.4.3.p1.4.bb:do_fetch) failed with exit code ‘1’
Can you please suggest a resolution ?
