I am using the BSP branch LinuxImageV2.6.1 to build images for my TK1 and everything works like expected.
Today i tried out the newest branch LinuxImageV2.7 and one of my recipes fails with the error below. What could be the reason for this?
One difference to other recipes is that the sources are get by svn with authentication, e.g:
SRC_URI = “svn://MY_SERVER;module=reset_server;protocol=https;user=SECRET;pswd=EVEN_MORE_SECRET”
ERROR: reset-server-1.0-r0 do_fetch: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:base_do_fetch(d)
0003:
File: '/home/user/oe-core/build/../layers/openembedded-core/meta/classes/base.bbclass', lineno: 132, function: base_do_fetch
0128: return
0129:
0130: try:
0131: fetcher = bb.fetch2.Fetch(src_uri, d)
*** 0132: fetcher.download()
0133: except bb.fetch2.BBFetchException as e:
0134: bb.fatal(str(e))
0135:}
0136:
File: '/home/user/oe-core/layers/openembedded-core/bitbake/lib/bb/fetch2/__init__.py', lineno: 1588, function: download
1584: localpath = ud.localpath
1585: elif m.try_premirror(ud, self.d):
1586: logger.debug(1, "Trying PREMIRRORS")
1587: mirrors = mirror_from_string(self.d.getVar('PREMIRRORS', True))
*** 1588: localpath = try_mirrors(self, self.d, ud, mirrors, False)
1589:
1590: if premirroronly:
1591: self.d.setVar("BB_NO_NETWORK", "1")
1592:
File: '/home/user/oe-core/layers/openembedded-core/bitbake/lib/bb/fetch2/__init__.py', lineno: 1024, function: try_mirrors
1020:
1021: uris, uds = build_mirroruris(origud, mirrors, ld)
1022:
1023: for index, uri in enumerate(uris):
*** 1024: ret = try_mirror_url(fetch, origud, uds[index], ld, check)
1025: if ret != False:
1026: return ret
1027: return None
1028:
File: '/home/user/oe-core/layers/openembedded-core/bitbake/lib/bb/fetch2/__init__.py', lineno: 949, function: try_mirror_url
0945: return found
0946: return False
0947:
0948: if not verify_donestamp(ud, ld, origud) or ud.method.need_update(ud, ld):
*** 0949: ud.method.download(ud, ld)
0950: if hasattr(ud.method,"build_mirror_data"):
0951: ud.method.build_mirror_data(ud, ld)
0952:
0953: if not ud.localpath or not os.path.exists(ud.localpath):
File: '/home/user/oe-core/layers/openembedded-core/bitbake/lib/bb/fetch2/wget.py', lineno: 114, function: download
0110:
0111: if ud.user:
0112: up = ud.user.split(":")
0113: print(up)
*** 0114: fetchcmd += " --user=%s --password=%s --auth-no-challenge" % (up[0],up[1])
0115:
0116: uri = ud.url.split(";")[0]
0117: if os.path.exists(ud.localpath):
0118: # file exists, but we didnt complete it.. trying again..
Exception: IndexError: list index out of range
