RROR: icu-59.1-r0 do_compile: oe_runmake failed
ERROR: icu-59.1-r0 do_compile: Function failed: do_compile (log file is located at /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/temp/log.do_compile.600)
ERROR: Logfile of failure stored in: /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/temp/log.do_compile.600
Log data follows:
| DEBUG: SITE files ['endian-little', 'bit-32', 'arm-common', 'arm-32', 'common-linux', 'common-glibc', 'arm-linux', 'arm-linux-gnueabi', 'common']
| DEBUG: Executing shell function do_compile
| NOTE: make -j 4
| Note: rebuild with "make VERBOSE=1 " to show all compiler parameters.
| make[0]: Making `all' in `stubdata'
| make[1]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/build/stubdata'
| make[1]: Nothing to be done for 'all'.
| make[1]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/build/stubdata'
| make[0]: Making `all' in `common'
| make[1]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/build/common'
| make[1]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/build/common'
| make[0]: Making `all' in `i18n'
| make[1]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/build/i18n'
| arm-angstrom-linux-gnueabi-g++ -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0=/usr/src/debug/icu/59.1-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot= -fvisibility-inlines-hidden -W -Wall -pedantic -Wpointer-arith -Wwrite-strings -Wno-long-long -std=c++11 -Wl,-O1 -Wl,--hash-style=gnu -shared -Wl,-Bsymbolic -Wl,-soname -Wl,libicui18n.so.59 -o ../lib/libicui18n.so.59.1 ucln_in.o fmtable.o format.o msgfmt.o umsg.o numfmt.o unum.o decimfmt.o decimalformatpattern.o dcfmtsym.o digitlst.o fmtable_cnv.o choicfmt.o datefmt.o smpdtfmt.o reldtfmt.o dtfmtsym.o udat.o dtptngen.o udatpg.o nfrs.o nfrule.o nfsubs.o rbnf.o numsys.o unumsys.o ucsdet.o ucal.o calendar.o gregocal.o timezone.o simpletz.o olsontz.o astro.o taiwncal.o buddhcal.o persncal.o islamcal.o japancal.o gregoimp.o hebrwcal.o indiancal.o chnsecal.o cecal.o coptccal.o dangical.o ethpccal.o coleitr.o coll.o sortkey.o bocsu.o ucoleitr.o ucol.o ucol_res.o ucol_sit.o collation.o collationsettings.o collationdata.o collationtailoring.o collationdatareader.o collationdatawriter.o collationfcd.o collationiterator.o utf16collationiterator.o utf8collationiterator.o uitercollationiterator.o collationsets.o collationcompare.o collationfastlatin.o collationkeys.o rulebasedcollator.o collationroot.o collationrootelements.o collationdatabuilder.o collationweights.o collationruleparser.o collationbuilder.o collationfastlatinbuilder.o strmatch.o usearch.o search.o stsearch.o translit.o utrans.o esctrn.o unesctrn.o funcrepl.o strrepl.o tridpars.o cpdtrans.o rbt.o rbt_data.o rbt_pars.o rbt_rule.o rbt_set.o nultrans.o remtrans.o casetrn.o titletrn.o tolowtrn.o toupptrn.o anytrans.o name2uni.o uni2name.o nortrans.o quant.o transreg.o brktrans.o regexcmp.o rematch.o repattrn.o regexst.o regextxt.o regeximp.o uregex.o uregexc.o ulocdata.o measfmt.o currfmt.o curramt.o currunit.o measure.o utmscale.o csdetect.o csmatch.o csr2022.o csrecog.o csrmbcs.o csrsbcs.o csrucode.o csrutf8.o inputext.o wintzimpl.o windtfmt.o winnmfmt.o basictz.o dtrule.o rbtz.o tzrule.o tztrans.o vtzone.o zonemeta.o standardplural.o upluralrules.o plurrule.o plurfmt.o selfmt.o dtitvfmt.o dtitvinf.o udateintervalformat.o tmunit.o tmutamt.o tmutfmt.o currpinf.o uspoof.o uspoof_impl.o uspoof_build.o uspoof_conf.o decfmtst.o smpdtfst.o ztrans.o zrule.o vzone.o fphdlimp.o fpositer.o ufieldpositer.o decNumber.o decContext.o alphaindex.o tznames.o tznames_impl.o tzgnames.o tzfmt.o compactdecimalformat.o gender.o region.o scriptset.o uregion.o reldatefmt.o quantityformatter.o measunit.o sharedbreakiterator.o scientificnumberformatter.o digitgrouping.o digitinterval.o digitformatter.o digitaffix.o valueformatter.o digitaffixesandpadding.o pluralaffix.o precision.o affixpatternparser.o smallintformatter.o decimfmtimpl.o visibledigits.o dayperiodrules.o -L../lib -licuuc -L../stubdata -licudata -lpthread -ldl -lm
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: smpdtfmt.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: dtfmtsym.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: udat.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: dtptngen.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: udatpg.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: nfrs.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: nfrule.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: nfsubs.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: rbnf.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: numsys.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: unumsys.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: ucsdet.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: ucal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: calendar.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: gregocal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: timezone.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: simpletz.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: olsontz.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: astro.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: taiwncal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: buddhcal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: persncal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: islamcal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: japancal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: gregoimp.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: hebrwcal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: indiancal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: chnsecal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: cecal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: coptccal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: dangical.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: ethpccal.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: coleitr.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: coll.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: sortkey.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: bocsu.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: ucoleitr.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: ucol.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: ucol_res.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: ucol_sit.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collation.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationsettings.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationdata.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationtailoring.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationdatareader.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationdatawriter.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationfcd.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationiterator.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: utf16collationiterator.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: utf8collationiterator.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: uitercollationiterator.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationsets.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationcompare.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationfastlatin.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationkeys.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: rulebasedcollator.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationroot.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationrootelements.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationdatabuilder.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationweights.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationruleparser.o: file is empty
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld: error: collationbuilder.o: file is empty
| collect2: error: ld returned 1 exit status
| Makefile:191: recipe for target '../lib/libicui18n.so.59.1' failed
| make[1]: *** [../lib/libicui18n.so.59.1] Error 1
| make[1]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/build/i18n'
| Makefile:147: recipe for target 'all-recursive' failed
| make: *** [all-recursive] Error 2
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/icu/59.1-r0/temp/log.do_compile.600)
ERROR: Task (/home/iot/work/toradex/ysn/openembedded/oe-core/build/../layers/openembedded-core/meta/recipes-support/icu/icu_59.1.bb:do_compile) failed with exit code '1'
ERROR: systemd-1_234-r0 do_compile: oe_runmake failed
ERROR: systemd-1_234-r0 do_compile: Function failed: do_compile (log file is located at /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/temp/log.do_compile.599)
ERROR: Logfile of failure stored in: /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/temp/log.do_compile.599
Log data follows:
| NOTE: make -j 4
| make --no-print-directory all-recursive
| Making all in .
| ./arm-angstrom-linux-gnueabi-libtool --tag=CC --mode=link arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z,relro -Wl,-z,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o systemd-update-utmp src/update-utmp/systemd_update_utmp-update-utmp.o libsystemd-shared.la
| ./arm-angstrom-linux-gnueabi-libtool --tag=CC --mode=link arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z,relro -Wl,-z,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o systemd-modules-load src/modules-load/systemd_modules_load-modules-load.o libsystemd-shared.la -lkmod
| ./arm-angstrom-linux-gnueabi-libtool --tag=CC --mode=link arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z,relro -Wl,-z,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o systemd-dissect src/dissect/dissect.o libsystemd-shared.la
| ./arm-angstrom-linux-gnueabi-libtool --tag=CC --mode=link arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z,relro -Wl,-z,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o systemd-hibernate-resume src/hibernate-resume/hibernate-resume.o libsystemd-shared.la
| arm-angstrom-linux-gnueabi-libtool: link: arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z -Wl,relro -Wl,-z -Wl,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o .libs/systemd-update-utmp src/update-utmp/systemd_update_utmp-update-utmp.o ./.libs/libsystemd-shared.so -lcap -lrt -lresolv -llzma -llz4 -lidn -lblkid -pthread -Wl,-rpath -Wl,/lib/systemd
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld.gold: error: src/update-utmp/systemd_update_utmp-update-utmp.o: file is empty
| ../sysdeps/arm/start.S:128: error: undefined reference to 'main'
| arm-angstrom-linux-gnueabi-libtool: link: arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z -Wl,relro -Wl,-z -Wl,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o .libs/systemd-hibernate-resume src/hibernate-resume/hibernate-resume.o ./.libs/libsystemd-shared.so -lcap -lrt -lresolv -llzma -llz4 -lidn -lblkid -pthread -Wl,-rpath -Wl,/lib/systemd
| Makefile:13777: recipe for target 'systemd-update-utmp' failed
| make[2]: *** [systemd-update-utmp] Error 1
| make[2]: *** Waiting for unfinished jobs....
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld.gold: error: src/hibernate-resume/hibernate-resume.o: file is empty
| Makefile:13053: recipe for target 'systemd-hibernate-resume' failed
| make[2]: *** [systemd-hibernate-resume] Error 1
| arm-angstrom-linux-gnueabi-libtool: link: arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z -Wl,relro -Wl,-z -Wl,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o .libs/systemd-dissect src/dissect/dissect.o ./.libs/libsystemd-shared.so -lcap -lrt -lresolv -llzma -llz4 -lidn -lblkid -pthread -Wl,-rpath -Wl,/lib/systemd
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld.gold: error: src/dissect/dissect.o: file is empty
| Makefile:12938: recipe for target 'systemd-dissect' failed
| make[2]: *** [systemd-dissect] Error 1
| arm-angstrom-linux-gnueabi-libtool: link: arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot -D__SANE_USERSPACE_TYPES__ -pipe -Wall -Wextra -Wundef -Wlogical-op -Wmissing-include-dirs -Wold-style-definition -Wpointer-arith -Winit-self -Wdeclaration-after-statement -Wfloat-equal -Wsuggest-attribute=noreturn -Werror=missing-prototypes -Werror=implicit-function-declaration -Werror=missing-declarations -Werror=return-type -Werror=incompatible-pointer-types -Werror=format=2 -Wstrict-prototypes -Wredundant-decls -Wmissing-noreturn -Wshadow -Wendif-labels -Wstrict-aliasing=2 -Wwrite-strings -Wno-unused-parameter -Wno-missing-field-initializers -Wno-unused-result -Wno-format-signedness -Werror=overflow -Wdate-time -Wnested-externs -ffast-math -fno-common -fdiagnostics-show-option -fno-strict-aliasing -fvisibility=hidden -fstack-protector -fstack-protector-strong -fPIE --param=ssp-buffer-size=4 -Werror=shadow -flto -ffunction-sections -fdata-sections -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0=/usr/src/debug/systemd/1_234-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot= -fno-schedule-insns -fno-schedule-insns2 -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined -Wl,-z -Wl,relro -Wl,-z -Wl,now -pie -Wl,-fuse-ld=gold -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o .libs/systemd-modules-load src/modules-load/systemd_modules_load-modules-load.o ./.libs/libsystemd-shared.so -lcap -lrt -lresolv -llzma -llz4 -lidn -lblkid -lkmod -pthread -Wl,-rpath -Wl,/lib/systemd
| /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi/../../libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/7.3.0/ld.gold: error: src/modules-load/systemd_modules_load-modules-load.o: file is empty
| Makefile:13223: recipe for target 'systemd-modules-load' failed
| make[2]: *** [systemd-modules-load] Error 1
| Makefile:23290: recipe for target 'all-recursive' failed
| make[1]: *** [all-recursive] Error 1
| Makefile:10403: recipe for target 'all' failed
| make: *** [all] Error 2
| ERROR: Function failed: do_compile (log file is located at /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/systemd/1_234-r0/temp/log.do_compile.599)
ERROR: Task (/home/iot/work/toradex/ysn/openembedded/oe-core/build/../layers/openembedded-core/meta/recipes-core/systemd/systemd_234.bb:do_compile) failed with exit code '1'
ERROR: libjpeg-turbo-1_1.5.2-r0 do_compile: oe_runmake failed
ERROR: libjpeg-turbo-1_1.5.2-r0 do_compile: Function failed: do_compile (log file is located at /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/temp/log.do_compile.601)
ERROR: Logfile of failure stored in: /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/temp/log.do_compile.601
Log data follows:
| NOTE: make -j 4
| make all-recursive
| make[1]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build'
| Making all in java
| make[2]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/java'
| make[2]: Nothing to be done for 'all'.
| make[2]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/java'
| Making all in simd
| make[2]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/simd'
| make all-am
| make[3]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/simd'
| make[3]: Nothing to be done for 'all-am'.
| make[3]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/simd'
| make[2]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/simd'
| Making all in md5
| make[2]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/md5'
| make[2]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build/md5'
| make[2]: Entering directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build'
| ./arm-angstrom-linux-gnueabi-libtool --tag=CC --mode=link arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0=/usr/src/debug/libjpeg-turbo/1_1.5.2-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot= -version-info 64:0:2 -no-undefined -Wl,--version-script,libjpeg.map -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o libjpeg.la -rpath /usr/lib jcapimin.lo jcapistd.lo jccoefct.lo jccolor.lo jcdctmgr.lo jchuff.lo jcinit.lo jcmainct.lo jcmarker.lo jcmaster.lo jcomapi.lo jcparam.lo jcphuff.lo jcprepct.lo jcsample.lo jctrans.lo jdapimin.lo jdapistd.lo jdatadst.lo jdatasrc.lo jdcoefct.lo jdcolor.lo jddctmgr.lo jdhuff.lo jdinput.lo jdmainct.lo jdmarker.lo jdmaster.lo jdmerge.lo jdphuff.lo jdpostct.lo jdsample.lo jdtrans.lo jerror.lo jfdctflt.lo jfdctfst.lo jfdctint.lo jidctflt.lo jidctfst.lo jidctint.lo jidctred.lo jquant1.lo jquant2.lo jutils.lo jmemmgr.lo jmemnobs.lo jaricom.lo jcarith.lo jdarith.lo simd/libsimd.la
| ./arm-angstrom-linux-gnueabi-libtool --tag=CC --mode=link arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0=/usr/src/debug/libjpeg-turbo/1_1.5.2-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot= -version-info 1:0:1 -no-undefined -Wl,--version-script,../libjpeg-turbo-1.5.2/turbojpeg-mapfile -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o libturbojpeg.la -rpath /usr/lib libturbojpeg_la-jcapimin.lo libturbojpeg_la-jcapistd.lo libturbojpeg_la-jccoefct.lo libturbojpeg_la-jccolor.lo libturbojpeg_la-jcdctmgr.lo libturbojpeg_la-jchuff.lo libturbojpeg_la-jcinit.lo libturbojpeg_la-jcmainct.lo libturbojpeg_la-jcmarker.lo libturbojpeg_la-jcmaster.lo libturbojpeg_la-jcomapi.lo libturbojpeg_la-jcparam.lo libturbojpeg_la-jcphuff.lo libturbojpeg_la-jcprepct.lo libturbojpeg_la-jcsample.lo libturbojpeg_la-jctrans.lo libturbojpeg_la-jdapimin.lo libturbojpeg_la-jdapistd.lo libturbojpeg_la-jdatadst.lo libturbojpeg_la-jdatasrc.lo libturbojpeg_la-jdcoefct.lo libturbojpeg_la-jdcolor.lo libturbojpeg_la-jddctmgr.lo libturbojpeg_la-jdhuff.lo libturbojpeg_la-jdinput.lo libturbojpeg_la-jdmainct.lo libturbojpeg_la-jdmarker.lo libturbojpeg_la-jdmaster.lo libturbojpeg_la-jdmerge.lo libturbojpeg_la-jdphuff.lo libturbojpeg_la-jdpostct.lo libturbojpeg_la-jdsample.lo libturbojpeg_la-jdtrans.lo libturbojpeg_la-jerror.lo libturbojpeg_la-jfdctflt.lo libturbojpeg_la-jfdctfst.lo libturbojpeg_la-jfdctint.lo libturbojpeg_la-jidctflt.lo libturbojpeg_la-jidctfst.lo libturbojpeg_la-jidctint.lo libturbojpeg_la-jidctred.lo libturbojpeg_la-jquant1.lo libturbojpeg_la-jquant2.lo libturbojpeg_la-jutils.lo libturbojpeg_la-jmemmgr.lo libturbojpeg_la-jmemnobs.lo libturbojpeg_la-jaricom.lo libturbojpeg_la-jcarith.lo libturbojpeg_la-jdarith.lo libturbojpeg_la-turbojpeg.lo libturbojpeg_la-transupp.lo libturbojpeg_la-jdatadst-tj.lo libturbojpeg_la-jdatasrc-tj.lo simd/libsimd.la
| arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I../libjpeg-turbo-1.5.2 -Wall -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0=/usr/src/debug/libjpeg-turbo/1_1.5.2-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot= -c -o jcstest.o ../libjpeg-turbo-1.5.2/jcstest.c
| arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I../libjpeg-turbo-1.5.2 -Wall -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0=/usr/src/debug/libjpeg-turbo/1_1.5.2-r0 -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/recipe-sysroot= -c -o tjunittest.o ../libjpeg-turbo-1.5.2/tjunittest.c
| arm-angstrom-linux-gnueabi-libtool: error: 'libturbojpeg_la-jcapimin.lo' is not a valid libtool object
| Makefile:926: recipe for target 'libturbojpeg.la' failed
| make[2]: *** [libturbojpeg.la] Error 1
| arm-angstrom-linux-gnueabi-libtool: error: 'jidctflt.lo' is not a valid libtool object
| Makefile:923: recipe for target 'libjpeg.la' failed
| make[2]: *** [libjpeg.la] Error 1
| make[2]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build'
| Makefile:2037: recipe for target 'all-recursive' failed
| make[1]: Leaving directory '/home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/build'
| Makefile:796: recipe for target 'all' failed
| ERROR: Function failed: do_compile (log file is located at /home/iot/work/toradex/ysn/openembedded/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/libjpeg-turbo/1_1.5.2-r0/temp/log.do_compile.601)
ERROR: Task (/home/iot/work/toradex/ysn/openembedded/oe-core/build/../layers/openembedded-core/meta/recipes-graphics/jpeg/libjpeg-turbo_1.5.2.bb:do_compile) failed with exit code '1'
ERROR: When reparsing /home/iot/work/toradex/ysn/openembedded/oe-core/build/../layers/meta-toradex-demos/recipes-images/images/angstrom-lxde-image.bb.do_image_teziimg, the basehash value changed from 22f44629e2c0d2e5351b824e822dda42 to 0c1205b7c3fdc7c423fee75de14ff7dd. The metadata is not deterministic and this needs to be fixed.
NOTE: Tasks Summary: Attempted 7084 tasks of which 7006 didn't need to be rerun and 3 failed.
NOTE: Writing buildhistory
Summary: 3 tasks failed:
Summary: There was 1 WARNING message shown.
Summary: There were 8 ERROR messages shown, returning a non-zero exit code.
iot@iptv:~/work/toradex/ysn/openembedded/oe-core/build$
iot@iptv:~/work/toradex/ysn/openembedded/oe-core/build$ ls
bitbake-cookerdaemon.log buildhistory cache conf downloads sstate-cache tmp-glibc
iot@iptv:~/work/toradex/ysn/openembedded/oe-core/build$ lsColibri iMX7D 512MBColibri iMX7D 512MBColibri iMX7D 512MB
hi @vijayyaga
Welcome to the Toradex Community!!!
Could you provide the version of the hardware and software of your module? Which Carrier Board are you using? (This Information should be filled in the Environment)
Concerning your issue:
- Which Git branch are you compiling?
- Have you done any changes before compiling? If yes, please share them!
- Could you provide which command did you launch?
- At last, which host distribution are using on your Build host?
Best regards, Jaski
