Bitbake add patch to patch
I would like add uap0 to NetworkInterfaceBlacklist
in connman main.conf
in bitbake image
oryginal patch set this new value
NetworkInterfaceBlacklist = vmnet,vboxnet,virbr,ifb,ve-,vb-,usb,rndis
I created patch and bbappend over devtool
devtool modify connman
devtool update-recipe -a ../../meta-xyz connman
devtool reset connman
and set new value
NetworkInterfaceBlacklist = vmnet,vboxnet,virbr,ifb,ve-,vb-,usb,rndis,uap0
connman_1.41.bbappend
FILESEXTRAPATHS:prepend := "${THISDIR}/${PN}:"
SRC_URI += "file://0001-add-uap0.patch"
0001-add-uap0.patch
From 7ddd502ddcc84928bda3422e6f8c36a155b49873 Mon Sep 17 00:00:00 2001
Date: Mon, 4 Dec 2023 13:14:37 +0100
Subject: [PATCH] add uap0
 src/main.conf | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/main.conf b/src/main.conf
index 435d266..d13ade0 100644
--- a/src/main.conf
+++ b/src/main.conf
@@ -67,7 +67,7 @@ BackgroundScanning = false
 # not be handled by ConnMan, if their first characters
 # match any of the list entries. Default value is
 # vmnet,vboxnet,virbr,ifb,ve-,vb-.
-NetworkInterfaceBlacklist = vmnet,vboxnet,virbr,ifb,ve-,vb-,usb,rndis
+NetworkInterfaceBlacklist = vmnet,vboxnet,virbr,ifb,ve-,vb-,usb,rndis,uap0
 # Allow ConnMan to change the system hostname. This can
 # happen for example if we receive DHCP hostname option.
But after try build image I have patch error
bitbake patch in wrong order first my patch then oryginal patch
how to change order for patch ?
I rename file to 1001-add-uap0.patch but
this didn’t solve the problem
How to patch in order:
0001-Adjust-main-configuration.patch
0001-add-uap0.patch
Hello @MariusM,
Thanks for reaching out to the Toradex Community!
Could you please try changing the priority of your custom layer (meta-xyz)? You should set BBFILE_PRIORITY_meta-xyz higher than BBFILE_PRIORITY_meta-toradex-demos so that it takes high precedence. You can also check the priorities of the layers using bitbake-layers show-layers.
Please let us know how that goes!
