Dear @jaski.tx,
Linux kernel: 4.14.117-3.0.2+ge43e3a2
Image: Console-Image 3.0b2
U-Boot: 2018.03_4.14.78_1.0.0
Boot log:
U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+g92d0497 (Feb 13 2020 - 10:23:19 +0000)
CPU: Freescale i.MX8QXP revB A35 at 1200 MHz at 44C
DRAM: 2 GiB
PMIC: device id: 0x40, revision id: 0x20, emrev 0, prog id fff
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX8 QuadXPlus 2GB Wi-Fi / BT IT V1.0B, Serial# 06494316
BuildInfo:
- SCFW cb6f758b, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF a-20190
- U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+g92d0497
flash target is MMC:0
Net: eth0: ethernet@5b040000 [PRIME]
Fastboot: Normal
Normal Boot
MMC: no card present
switch to partitions #0, OK
12776 bytes read in 12 ms (1 MiB/s)
## Starting auxiliary core at 0x80280000 ...
Power on aux core 0
Copy image from 0x80280000 to 0x34fe0000
Start M4
bootaux complete
Scanning mmc 0:1...
Found U-Boot script /boot.scr
1202 bytes read in 8 ms (146.5 KiB/s)
## Executing script at 86000000
80891 bytes read in 9 ms (8.6 MiB/s)
23104000 bytes read in 463 ms (47.6 MiB/s)
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Device Tree to 00000000fd668000, end 00000000fd67ebfa ... OK
/dma-controller@591F0000, 62300
/dma-controller@599F0000, 63188
/dma-controller@5a1f0000, 61424
Starting kernel ...
[ 0.000000] Linux version 4.14.117-3.0.2+ge43e3a2 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Tue Mar 3 15:37:38 UTC 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] Machine model: Toradex Colibri iMX8QXP/DX on Colibri Evaluation Board V3
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000096000000, size 960 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 28 MiB
[ 0.000000] OF: reserved mem: initialized node rpmsg_dma@0x90400000, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xfff7d300-0xfff7f0ff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080200000-0x00000000ffffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080200000-0x0000000083ffffff]
[ 0.000000] node 0: [mem 0x0000000086200000-0x000000008fffffff]
[ 0.000000] node 0: [mem 0x0000000094c00000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 487432
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: root=PARTUUID=1de869f2-02 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 811520K/1982464K available (13308K kernel code, 1698K rwdata, 6244K rodata, 1280K init, 429K bss, 187904K reserved, 983040K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008d80000 ( 13312 KB)
[ 0.000000] .rodata : 0xffff000008d80000 - 0xffff0000093a0000 ( 6272 KB)
[ 0.000000] .init : 0xffff0000093a0000 - 0xffff0000094e0000 ( 1280 KB)
[ 0.000000] .data : 0xffff0000094e0000 - 0xffff000009688a00 ( 1699 KB)
[ 0.000000] .bss : 0xffff000009688a00 - 0xffff0000096f4098 ( 430 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000008000 - 0xffff7e0002000000 ( 31 MB actual)
[ 0.000000] memory : 0xffff800000200000 - 0xffff800080000000 ( 2046 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.003196] Console: colour dummy device 80x25
[ 0.003901] console [tty0] enabled
[ 0.003969] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.003997] pid_max: default: 32768 minimum: 301
[ 0.004085] Security Framework initialized
[ 0.004772] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.005127] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.005170] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005197] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.019917] ASID allocator initialised with 32768 entries
[ 0.027914] Hierarchical SRCU implementation.
[ 0.037246] *****Initialized MU
[ 0.037291] ***** imx8_init_pm_domains *****
[ 0.038478] CPU identified as i.MX8QXP, silicon rev 1.1
[ 0.040244] EFI services will not be available.
[ 0.048161] smp: Bringing up secondary CPUs ...
[ 0.076568] Detected VIPT I-cache on CPU1
[ 0.076598] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[ 0.076632] CPU1: Booted secondary processor [410fd042]
[ 0.104606] Detected VIPT I-cache on CPU2
[ 0.104625] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[ 0.104645] CPU2: Booted secondary processor [410fd042]
[ 0.132665] Detected VIPT I-cache on CPU3
[ 0.132683] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[ 0.132700] CPU3: Booted secondary processor [410fd042]
[ 0.132764] smp: Brought up 1 node, 4 CPUs
[ 0.132872] SMP: Total of 4 processors activated.
[ 0.132886] CPU features: detected feature: GIC system register CPU interface
[ 0.132903] CPU features: detected feature: 32-bit EL0 Support
[ 0.132918] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.137616] CPU: All CPU(s) started at EL2
[ 0.137641] alternatives: patching kernel code
[ 0.138397] devtmpfs: initialized
[ 0.151868] random: get_random_u32 called from bucket_table_alloc+0x104/0x268 with crng_init=0
[ 0.152306] Registered cp15_barrier emulation handler
[ 0.152331] Registered setend emulation handler
[ 0.152591] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.152650] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.178970] pinctrl core: initialized pinctrl subsystem
[ 0.181351] DMI not present or invalid.
[ 0.181739] NET: Registered protocol family 16
[ 0.184397] cpuidle: using governor menu
[ 0.185907] vdso: 2 pages (1 code @ ffff000008d86000, 1 data @ ffff0000094e4000)
[ 0.185946] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.192781] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.193570] Serial: AMBA PL011 UART driver
[ 0.193746] imx rpmsg driver is registered.
[ 0.196218] MU and Power domains initialized
[ 0.196247] ***** imx8qxp_clocks_init *****
[ 0.253780] imx8qxp-pinctrl iomuxc: initialized IMX pinctrl driver
[ 0.276349] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.288629] MU is ready for cross core communication!
[ 0.288860] imx-rpmsg 90000000.rpmsg: assigned reserved memory node rpmsg_dma@0x90400000
[ 0.289363] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.310326] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 0.327750] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.349124] ACPI: Interpreter disabled.
[ 0.359708] vgaarb: loaded
[ 0.360059] SCSI subsystem initialized
[ 0.360531] usbcore: registered new interface driver usbfs
[ 0.360600] usbcore: registered new interface driver hub
[ 0.360693] usbcore: registered new device driver usb
[ 0.361455] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.364226] i2c i2c-16: LPI2C adapter registered
[ 0.365611] i2c i2c-17: LPI2C adapter registered
[ 0.366994] media: Linux media interface: v0.10
[ 0.367057] Linux video capture interface: v2.00
[ 0.367254] pps_core: LinuxPPS API ver. 1 registered
[ 0.367271] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.367306] PTP clock support registered
[ 0.367543] EDAC MC: Ver: 3.0.0
[ 0.367838] dmi: Firmware registration failed.
[ 0.368675] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.369328] Advanced Linux Sound Architecture Driver Initialized.
[ 0.370012] Bluetooth: Core ver 2.22
[ 0.370078] NET: Registered protocol family 31
[ 0.370091] Bluetooth: HCI device and connection manager initialized
[ 0.370113] Bluetooth: HCI socket layer initialized
[ 0.370129] Bluetooth: L2CAP socket layer initialized
[ 0.370179] Bluetooth: SCO socket layer initialized
[ 0.371016] clocksource: Switched to clocksource arch_sys_counter
[ 0.371183] VFS: Disk quotas dquot_6.6.0
[ 0.371252] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.371402] pnp: PnP ACPI: disabled
[ 0.378238] NET: Registered protocol family 2
[ 0.378891] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.379112] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.379346] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.379465] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.379527] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.379696] NET: Registered protocol family 1
[ 0.380370] RPC: Registered named UNIX socket transport module.
[ 0.380389] RPC: Registered udp transport module.
[ 0.380403] RPC: Registered tcp transport module.
[ 0.380416] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.381588] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.382066] kvm [1]: 8-bit VMID
[ 0.383167] kvm [1]: GICv3: no GICV resource entry
[ 0.383182] kvm [1]: disabling GICv2 emulation
[ 0.383216] kvm [1]: GIC system register CPU interface enabled
[ 0.383293] kvm [1]: vgic interrupt IRQ1
[ 0.383385] kvm [1]: Hyp mode initialized successfully
[ 0.385992] audit: initializing netlink subsys (disabled)
[ 0.386124] audit: type=2000 audit(0.380:1): state=initialized audit_enabled=0 res=1
[ 0.386500] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[ 0.393451] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.394138] NFS: Registering the id_resolver key type
[ 0.394181] Key type id_resolver registered
[ 0.394193] Key type id_legacy registered
[ 0.394212] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.394245] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.394911] 9p: Installing v9fs 9p2000 file system support
[ 0.400270] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.400306] io scheduler noop registered
[ 0.400465] io scheduler cfq registered (default)
[ 0.400481] io scheduler mq-deadline registered
[ 0.400495] io scheduler kyber registered
[ 0.418635] imx6q-pcie 5f010000.pcie: 5f010000.pcie supply epdev_on not found, using dummy regulator
[ 0.418920] OF: PCI: host bridge /pcie@0x5f010000 ranges:
[ 0.418942] OF: PCI: No bus range found for /pcie@0x5f010000, using [bus 00-ff]
[ 0.418969] OF: PCI: IO 0x7ff80000..0x7ff8ffff -> 0x00000000
[ 0.418996] OF: PCI: MEM 0x70000000..0x7fefffff -> 0x70000000
[ 0.423547] imx6q-pcie 5f010000.pcie: pcie phy pll is locked.
[ 0.556530] imx6q-pcie 5f010000.pcie: Link: Gen2 disabled
[ 0.556551] imx6q-pcie 5f010000.pcie: Link up, Gen1
[ 0.558113] imx6q-pcie 5f010000.pcie: PCI host bridge to bus 0000:00
[ 0.558150] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.558167] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.558185] pci_bus 0000:00: root bus resource [mem 0x70000000-0x7fefffff]
[ 0.571143] pci 0000:00:00.0: BAR 0: assigned [mem 0x70000000-0x70ffffff 64bit]
[ 0.571175] pci 0000:00:00.0: BAR 6: assigned [mem 0x71000000-0x71ffffff pref]
[ 0.571199] pci 0000:00:00.0: BAR 15: assigned [mem 0x72000000-0x721fffff 64bit pref]
[ 0.571226] pci 0000:01:00.0: BAR 0: assigned [mem 0x72000000-0x720fffff 64bit pref]
[ 0.571289] pci 0000:01:00.0: BAR 2: assigned [mem 0x72100000-0x721fffff 64bit pref]
[ 0.571352] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.571371] pci 0000:00:00.0: bridge window [mem 0x72000000-0x721fffff 64bit pref]
[ 0.572289] pcieport 0000:00:00.0: Signaling PME with IRQ 390
[ 0.572442] pcieport 0000:00:00.0: AER enabled with IRQ 391
[ 0.574093] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.582377] mxs-dma 5b810000.dma-apbh: initialized
[ 0.584506] Bus freq driver module loaded
[ 0.592085] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.595248] SuperH (H)SCI(F) driver initialized
[ 0.596326] msm_serial: driver initialized
[ 0.597768] 5a080000.serial: ttyLP2 at MMIO 0x5a080010 (irq = 46, base_baud = 5000000) is a FSL_LPUART
[ 0.599657] 5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 47, base_baud = 5000000) is a FSL_LPUART
[ 0.599703] Serial: Console lpuart rounded baud ratefrom 575539 to 115200
[ 1.811013] console [ttyLP3] enabled
